Protection From The Cold Weather
I currently live in Phoenix AZ and I am considering moving to Salt Lake City in a few months, I was wondering what I can do to protect my truck from the colder and wetter climate. I'm thinking along the lines of protection from salt that might be put down on the roads in winter and just having more moisture in the air than Phoenix.
I remember seeing a couple guys on TV once talk about a product that you spray inside the wheel well and perhaps along the underside of the truck for protection.
I don't think it really makes a difference but I drive a 2006 crew cab 2WD.
Any help would be great, thanks.
What areas are you talking about? Frame, paint, rims?
I use the following product on my paint. It is a very good and durable sealant. Water still beads for quite some time
http://www.autogeek.net/dp-poli-coat-32oz.html
For my rims I apply this wheel glaze about every 4-6 wks
http://www.autogeek.net/dp-wheel-glaze.html
I'm relly just concerned with any area that could rust or rot from the cold or moisture. (frame, suspension, exhaust, paint etc.) I've never lived in colder climates so I don't really know how the truck will be affected.
Any ideas or suggestions you might have would be great.
I think the best thing to do is wash it frequently to keep the salt off. They salt the roads up here till the pavements white. I usually wash it every couple weeks in the winter and haven't ever had an issue with my last 3 trucks rusting.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
