Decreasing Gas Mileage
My 2001 Yukon's MPG has dropped by nearly 1/3 in the past few months, going from roughly 330-350 miles a tank to barely over 200 now. This started after running a can of sea-foam through the gas... It's not throwing any codes, but the exhaust seems pretty rich from the soot on the tailpipe. Prior to the sea-foam I had changed the plugs and wires. I haven't pulled a plug to see how they look. Thoughts, suggestions, questions, comments??!
When was the last time you've cleaned the MAF sensor and/or throttle body? Have you changed location of where you normally get gas? Has anything else changes like tires or even tire pressure? I'd start with those and see if that changes anything.
Haven't cleaned the MAF. I've been getting gas at a Sam's prior to the decrease in mileage. I did notice that they do have the contains 10% ethanol sticker, almost impossible to avoid stations that blend. Tires were changed but stayed with the size prior to.
i love sea foam but there is one downside to it. if for some reason you have sediment or any type of build up in your tank, filter, or lines it can cause this to dislodge and begin building up carbon in the engine. the main issue on your year of vehicle is on the control plate in the throttle valve assembly. this can get a lot of debris on it and cause issues with MPG. go have your intake cleaned at your local shop (usually not more then $50) and you should see some differences
if it make su feel better my 09 sierra went from 16 in the warmer months to 14 the last 2 months in the cold.
Just pulled the MAF. Haven't located a tech article on properly cleaning this... Bought a can of electrical cleaner specified mass air. I'm assuming just spray the same direction as air flow?
Future reference, if you want to use SeaFoam, change the plugs AFTER you use SeaFoam. Also, change brands of gas and run some Techron cleaner through it. I have had good luck with SeaFoam.
My dad had his mileage drop and drop on his 2008 Chev 2500 with 6.0 and he had been getting gas at Costco. He changed to Shell and it went from 12.6 to 16mpg.
Also check your air cleaner and make sure it is clean.
Wasn't immediately after changing plugs but definitely won't be using it again in the future. Cleaned the MAF and reinspected the air filter to make sure it was still clean. Almost through another tank and still no difference...
Had read about the fuel pressure regulator as a potential culprit. Anyone changed one out on the 5.3? Is it under the plenum or on the fuel rail?
If you've convinced yourself that the intake system is in good working order, you might look into ignition timing as a culprit. That kind of drop in mileage might be linked to a timing issue. Inadequate timing advance at cruise/light throttle can reduce mileage. On these engines, there could be a number of reasons the timing isn't getting to where it should. The nock sensor might be something to look at. You might do well to look into a custom tune where they hook up your truck and do the tune and verify everything while driving/dyno testing. The tuner will likely spot the problem right away.
I'm not convinced of anything yet. Regarding scanning the vehicle, while unrelated to tuning, I am still not seeing any trouble codes or pending codes. I have a Landrover that requires a proprietary platform (testbook) from the dealer that enables them to scan more than an OBDII scanner. Are GM vehicles similar in this regard?
Chris,
I'm not all that knowledgeable about the diagnosis software, but, I do recall seeing some of the software capabilities of EFI Live sofware when my Blackbear tune was done. It's far and away more than a simple code reader can do. You can see all sorts of engine/trans parameters, including fuel and ignition. That's why I suggested the custom tune route.
The autocal allows a person to log/view all of the EFI data, but not edit parameters directly... which certainly may be useful for diags.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
