Headlights
Can anyone tell me where I can find a diagram or directions for having all the headlights AND fog lights stay on when the high beams are turned on in a 2010 Sierra 1500. I know it's not "legal" and all that, but I'll take my chances. If anyone can help I'd appreciate it!!
Well the only ones u need to worry about is the fogs since the Highs and Lows stay on together with the GMT-900's. For the fogs there is a post around here that shows you need a Diode that goes from the high relay to the fog relay in the Fuse box under the hood. This is one way to do it and then of course you can use a powered relay. The highs would be your signal and pull the power from the battery. The diode would be the simplest way though.
Thanks!!!!!
You might want to check ur states laws & statutes. In a lot of states it is illegal to have more than 4
forward facing lights on at any one time. That is why when you turn the fogs on, it turns the high
beams off. If you go down the road with 6 on, they will get ya.
La RS 32:326 (Louisiana statutes)
§326. Number of driving lamps required or permitted; parking lights
A. At all times specified in R.S. 32:301, at least two lighted lamps shall be displayed, one on each side at the front of every motor vehicle other than a motorcycle or motor-driven cycle, except when such vehicle is parked subject to regulations governing lights on parked vehicles.
B. Whenever a motor vehicle equipped with head lamps as herein required is also equipped with any auxiliary lamps or any other lamp on the front thereof projecting a beam of intensity greater than 300 candlepower, not more than a total of four of any such lamps on the front of a vehicle shall be lighted at any one time when upon a highway of this state.
C. No moving vehicle upon any public highway within this state shall be operated with only the parking lights for illumination.
Acts 1962, No. 310, §1. Amended by Acts 1964, No. 331, §1.
Just a heads up & FYI.
Don't think he gives a shiz..... :P
http://www.gm-trucks.com/forums/index.php?...c=102308&hl=
Thanks for the link. Great pictures, definetly appreciate it.!!
Not a problem. Get it all hooked up
