I broke down and bought one
RyanbabZ71
Well last night at work i broke down and decided to buy a cell phone (free phone plus $50 rebate)
$34.99 a month (500 weekday mins and 3000 night and weekend)
I didnt think id see the day.  But with everything going on i figure if it comes in handy once itll be well worth it
Welcome to the 90s  :)
:jester:  :flag:  :lol:
I cancelled my land-line phone at home over a year ago, I'm saving lots of money thanks to the locak phone company and the B.S. 'local zone call' charges
All I use is my mobile phone now  :thumb:
Reason I don't have a cell phone:  People can find me!
Reason I don't have a tatoo:  Positive Identification! :jester:
Ha, thought about that first point myself.  I tend to use the caller id feature or let voicemail pick it up if I don't want to talk.  I avoid giving the number out as well.  I didn't really use my first 1 too much, but when the contract was up, I changed providers and got a better deal, so now it gets some use.
shocking pure shocking. :)  :flag:  :jester:
I'm still against cell phones and pagers.  Although the pager fad has totally passed..... lol I don't want to be found that and where ever I am, whoever I am with someone has a cell phone, so why buy one?   :jester:
I used to swear that I would never own a cell phone in my life.  But after having one for about two years, I couldn't go without it.  I only use a landline for occasional local calls, or if I am running low on my minutes.  Which seems to happen monthly since this one girl calls me all the time on my cell phone.  Wasn't so bad when it was just my buddies calling me, but for some reason this girl talks a lot more then my buddies.  LOL
If you dont mind my asking, what brand phone did you go with? It sounds like a pretty good deal, my phone contract is up in a month, and i need to be shopping around...
I got a nokia 5165 i think???
I have to say at school yesterday 3 of us were messing around cause we found out we could send text messages and emails.  Both of my friends have $150 phones and i was the only one who could get a signal and receive the messages.
Free phone plus $50 rebate is awesome
    Greg3160
    Greg3160
  • Who's Online   4 Members, 0 Anonymous, 870 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
