Dominator Ii Steps And Oem Mud Flaps
I'm ready to pull the trigger on some Go Rhino Dominator II nerf bars. I did a search and found this topic: http://www.gm-trucks.com/forums/index.php?showtopic=104915 It says the steps won't fit with GM mud flaps which I already have installed. Anyone running these steps with GM mud flaps?
EDIT: I just realized that those are N-fab bars in the link. :lol: Do the Go Rhino's have this problem also?
i have weathertech flaps and go rhinos. they fit fine
Are they molded flaps like the GM ones?
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
