Finally...i Understand
rws262
So after nearly two days of looking at metric tire sizes, i finally have grasped what they are trying to tell me.
Now on to the question of what to get. I am getting Cooper Zeon LTZ's on 20x9 rims. The tires i have now are stock 275/55/R20 and i figured i would get the same size, unless i can get away with a 275/60/R20 without a level/lift kit. What do you think, can i get 275/60/R20's without a lift kit? Its a tire that is 1.12 inches taller (if im doing this right) but the rims are now going to be 1/2 inch wider. and where does rim offset figure into this?
Now on to the lift question. I like the rake in my truck as i pull a lot of heavy stuff, mainly racecars. What kind of lift (if i need it) will get me up to fit the tires but keep the rake? And how much bigger lift would i have to go to get something, say, 305/55/R20?
Next question, if i hook up to the race trailer and it sags down a little bit but still fairly level, will the rear tires rub at all?
Last question: if i go with 275/60/R20, is there anything that has to be calibrated in speedo or anything else?
Thanks for all the help guys. I have learned a lot from this site.
You will need a 2" leveling kit in order to fit a 275/60/20, and they will still likely rub some.
What is the offset of the wheels you will be running?
If you want to run 305/55/20's, you need a minimum of 4" of lift. 5-6" is best. I ran a 2" leveling kit/3" body lift with those tires.
Rear tires shouldn't rub at all.
Your speedo will likely be off a little..not sure how much.
Would 305/50/20's work on a 20x9.5" wheel, +35mm backspace, and a 2" RC leveling kit? its a 32" tall tire, thats 12" wide. Not sure how the extra inch wide rim will work.
If you run a 275/60/20 instead of OEM 275/55/20 your speedo will be off a little over 2 mph unless you get a BB tune to compensate.
I'd like to get the Cooper Zeon in 275/60/20 when these crappy Goodyear Eagle LS2 wear out but not sure if the RC 2" level kit will allow me to run those tires or if I need the Bilstein pre-load level unit I see at offroadwarehouse.com or shockwarehouse.com.
Put up some pics when you decide and get everything installed.
That one bad ass rig you have :)
depending on how nice your dealer is they can do it for you too. if its a common size that they already have programmed they may do it for free- otherwise you'll have to pay substantially more if its an off size. the dealer i used to go to reflashed for me when i went from the stock 265s to the 285s (33s). even if they dont have your exact size you can get something close.
That one bad ass rig you have :uhoh:
:D
Why thank you sir. I often regret not sticking to my tradition and gettting a white one. Yours is quite nice as well.
    tonyb2760
    tonyb2760
  • Who's Online   6 Members, 0 Anonymous, 489 Guests (See full list)
