Help With Factory Stereo Equipment
I have an 07 silverado classic 1500 lt1 so basically the same as an 06, i need to install aftermarket speakers in the front and i dont want to install an amp or new head unit, i have seen some people talk about their head units having an amp built in to it. did these radio's have an amp built in to it and what is there output wattage for there radio's the speakers i have found are 85 watt rms and i want to make sure they will sound good. oh and i do not have the bose sound system
The factory head unit does have a built in amp, I dont know for what the wattages is, they never advertise them but most stock head units are in the 10 to 15 watts per channel. To measure it accurately you need some expensive equipment but you can kind of estimate it by hooking a volt meter to the speaker leads while the stereo is one and them multiply volts by volts and divide by speaker impedance equals watts, so say if it was 5volt reading and 4ohm speaker you do (5x5)/4= 6.25 watts.
Speakers rated at 85w rms will likely not be powered enough to sound their best from the factory head unit, you will find they are weak on bass. JL Audio Evolution TR speakers are usually a good match for stock head units as they perform well at low wattages.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
