Wheelhouse Liners
Has anyone ordered the G.M. wheelhouse liners do they come with install hardware? heard they were no-drill w/factory push-pins? and screws For the rear fenders . If so how was the installation I have the plastic oem mud flapson now and would like to reuse them and not sure how to mount everything. Any help will be great
Dave :P:crackup::crackup:
They are really easy and come with very detailed instructions and all mounting hardware. They will fit very tightly and you probably don't have to use anything but the push pins that are on the fender lip, but there are a few self tapping screws you are supposed to put in on either side to help hold them in. They should not interfere at all with splash guards as they sit completely inside the fender lip when installed.
has anyone called GM and let them know thay are forgetting to put the fender-liners in??
Should be standard equipment...I guess there are no gravel sections on the GM test track
I wish GM would make those fender lines for the 3500 dually. :)
it's called rubberized undercoating. It's about 6 bucks a can at wally. I used a can about a year ago and it still looks great. And my truck is silver. I just rinse out the fenders when I wash it and don't have to worry about mud and stuff getting behind any cheesy liners.
Another good point!...There is alot of undercoating on my truck, Looks like they covered the chassis nicely..so why didn't GM spray the wheel wells!
Oh..I guess they they wanted to sell fender liners :cool:
  • 2 months later...
Dave :):thumbs::thumbs:
I had the dealer install mine. They put in 6 screws for each wheel well.
  • 1 month later...
We need before and after pictures of the wheel wells! ...please.
Also, what was the approximate price from the dealer for parts only?
The plastic fasteners they supply are kind of lame. I can't get mine to sit flat. Anyone else have this problem?
I took the plastic tabs off that fit on the fender lip since the dealer used some self tapping screws inside the wheel well to hold them in place. Looks much better not seeing the frame or all the way through to the other side.
