Bed Lights
The look great! What manufacturer did you use for the LEDs? Where is the switch placed? Where did you tie in to get the power feed?
Sorry, looks like I forgot the picture of the switch, I will get one tomorrow. I mounted the switch in the little hole in the side of the bed near the tailgate. I have post hole covers so other then water coming up from under the truck it should be fairly water tight. Picked up the switch and the LEDs from Autozone. The LEDs 24 inch strips, two in a pack and I used two packs. I pulled power from the back of the 7-pin on the bumper. I crimped, soldered and heat wrapped all the connectors and then used wire looms to keep everything nice and neat.
LEDs
Switch
