Temp/compass Issue In Rearview Mirror
Hey All,
I have a 2003 2500HD with the temp/comp display in the rearview mirror. Most of the time now it goes very dim and is really hard to read. Sometimes it is nice and bright like it should be... (and no the problem isnt just because my head lights are on)
I checked all the fuses and everything seems ok there, does it mean that the display is slowly dying or is there something I am missing?
Finally, should mine be an auto dimming mirror as well or are there dimming and non dimming temp/compass mirrors?
Thanks
Lee
Check the power and ground to the mirror when it is acting up. If you have full 12 volts and good ground the issue is inside the mirror.
And is the best way to do that to pull the plug out of the mirror and check it that way?
Anyone have a plug wiring diagram?
Looks like it is a 16 way connector
Terminal 8 is ground- black wire
terminal 12 is ign 1 voltage - yellow wire
<A href="#tab2-885557">
Inside Rearview Mirror
Connector Part Information
• 15324871
• 16-Way (BLK)
Pin
Wire Color Circuit No. Function
1-2---- Not Used
3 DK BLU 2307 Passenger Air Bag On Indicator Control
4 DK GRN 2308 Passenger Air Bag Off Indicator Control
5 GRY 1690 Automatic Day/Night Mirror Signal - w/ YE9
Not Used - w/o YE9
6 DK GRN/WHT 636 Ambient Air Temperature Sensor Signal - w/ YE9
Not Used - w/o YE9
7 BLK/WHT 1704 Low Reference - w/ YE9
-- Not Used - w/o YE9
8 BLK 1050 Ground
9 LT GRN 24 Backup Lamp Supply Voltage - w/ YE9
10 -- -- Not Used
11 DK GRN/WHT 2514 Keypad Signal - w/ UE1
-- Not Used - w/o UE1
12 LT GRN/BLK 2515 Keypad Supply Voltage - w/ UE1
13 YEL 1139 Ignition 1 Voltage
14 YEL/BLK 2516 Keypad Green LED Signal
15 BRN/WHT 2517 Keypad Red LED Signal
16 PNK 1691 Automatic Day/Night Mirror Low Reference - w/ YE9
  • 4 weeks later...
I am having the same issue with my 04 z71 except mine is only when it is either snowing or raining. I have yet to try to test the plug, but Im thinking it has something to do with the temp sensor on the radiator support but Im not sure. It also doesnt Dim or change LED color ever. Please Help.
