So, today I used a Motive Power bleeder to change out my brake fluid. It had been about 3 years and it was black as tar. It was pretty successful, used about 2.25 quarts of fluid total. If I had to do it again I would use a baster to change out the master cylinder first then use the motive unit. That would save a lot of time (instead of using the motive unit to totally exchange the master cylinder's entire contents through the brake bleeder). I used the Delco Supreme 11 stuff recommended by GM. I can't think of a better way to change out the fluid.
Did you have any trouble with the ABS on the truck? I've heard of problems with the newer trucks and the ABS when bleeding the brakes.
I may be wrong, but isn't that if you run the resevoir dry?
How much are they and where can you get one? I noticed my fluid is very dirty looking and I'm sure after 12 years it should probably be changed!
