Time For A Sound Upgrade
Well, I just had my stock speakers replaced under warranty. That was 2 weeks ago, and the new ones are already blown. I really don't listen to my music that loud, but maybe I am deaf. Anyway, I like my stock deck. My warranty is now up and before I dive into the performance aspect of the truck, I want some decent sound. My plan is to just replace the door speakers, and maybe the pillar tweeters. I have looked around and found ALL kinds of speakers. I really don't know which ones to chose that will benefit me most for this application. I found that I can get some adapters and run 6 1/2's. Now, which speakers do you guys prefer? Cost really isn't a factor, but don't want to spend a crap load on just door speakers either. I would also prefer to not have to run an amp. Just want to keep it simple, but add slightly better sounds with some speakers that I wont blow in a weeks time.
Thanks in advance!!
What kind of sound are you looking for? Clear or more bass?
Guess I left that out. I like a clear sound, but a slight increase in bass would be nice as well.
Your best bet if you plan to keep the factory head unit and want clear sound are JL Audio TR650-CXi in the doors and use foam baffles behind them and then replace the tweeters with Rockford Fosgate P1T-S set at -4 db, that combo will sound good and run you about $300. If you want a bit more sound quality but would be pushing the limits of what the factory head unit can power you could look at JL Audio C2-650x speakers with foam baffles and replace the tweeters with Rockford Fosgate T1T-S which would run you about $400.
Thanks for the quick and helpful response. I will check those out.
Checked them out. Seems they are 6 3/4. The adapters say up to a 6 1/2. Will they still work? Crutchfield seems to think so but just want to be certain.
infinity refrence speakers are sound really nice, also i have GM compatible (whatever that means) Pioneer speakers in my 01 and im happy with them
Yes they will, they are slightly oversized 6.5 but the adapters fit up to 6.75
I also made a post of when I installed those tweeters to my truck, pretty simple http://www.gm-trucks.com/forums/index.php?showtopic=128500
Cool, thanks again TJ. Actually saw your post prior to making mine. Good stuff. I will def use it as a reference when I do mine. Not looking forward to it though, haha. I hate taking all of the panels off of the doors. Had to do it when I installed my mirrors. Oh well, round 2 should be easier.
    Brandon 29
    Brandon 29
  • Who's Online   4 Members, 0 Anonymous, 591 Guests (See full list)
