Couple Complaints On My Gmc Truck
I have a few questions on my 09 GMC Sierra that are areas of concern and I wanted to see if you guys had run into any of these, or have solutions to them.
1. Rattle/Clicking sound that comes from the Steering Column/Knee Bolster area when hitting bumps in the road. Can't seem to track it down easily, I guess I'm going to have to take the knee bolster off of the dash and see if anything is loose...
2. Rattle/Vibration from the Dash right above the Instrument Panel...sounds just like some of the chattering gauges in the GMT 800 trucks, however if I put the slightest bit of pressure on the dash right above the I/P the noise goes away? I have no idea on how to fix this one.
3. The BOSE Subwoofer...apparently this thing has so much BASS its not even good...basically with the BASS set in the middle of the range, if you are listening to a song with BASS the whole console/center of the dash area rattles like the whole truck is going to come undone....has anyone ran into this on their GMT 900 with Bose....I know the Sub assembly is bolted to the floor, I was wondering if there was some sort of rubber bushings that a guy could put on the mounting studs to maybe eliminate the vibration which then feeds into the console/dash, etc.
These are all on the SLT styled dash...the truck has 15K miles on it.
:sick: I didn't have a single rattle or vibration in my 07, I'm hoping the 11 is the same. So far so good. They DRIVE ME NUT. Not sure why your getting those. Maybe a trip to the dealership might be in order.
:sick: I didn't have a single rattle or vibration in my 07, I'm hoping the 11 is the same. So far so good. They DRIVE ME NUT. Not sure why your getting those. Maybe a trip to the dealership might be in order. :D
Well hopefully your 11' treats you good to...my 07 was the perfect truck, I honestly wonder why I ever traded it....I don't like rattles either and this 2009 has been of less quality than any of them I have ever owned. Its very disappointing to have a good truck, trade it for a newer one that comes with minor annoying things. The BOSE thing is probably the worst, it literally sounds like the damn thing is coming apart!
I had that same rattle that you do I believe. I had the 4wd drive get locked in 4 Low and took it to the dealer a good friend of mine works at the dealer and always have him do the work. Long story short, he found that knee bolster broke the plastic rivets and was causing that annoying squeak and it took care of the noise in the dash. Check that out first I hope this works for you as my truck is a pleasure to drive again, but it always should be, LOL
i nevr had any of those rattles in any one of my last three 900's ('08 Sierra, '09 Tahoe LTZ, '10 Yukon Denali) two had the bose with sub and the system sounded tremendous, no rattles (yet).. gotta be a couple loose parts just take it in and have the mechanic listen to them with you there so he knows what he needs to fix, don't just let a service advisor hear them, insist on the mechanic who will be working on your truck listen to it.
No problems with my bose. Maybe you can chech under their. Just lift out the square tray and look around.
  • 5 months later...
"1. Rattle/Clicking sound that comes from the Steering Column/Knee Bolster area when hitting bumps in the road. Can't seem to track it down easily, I guess I'm going to have to take the knee bolster off of the dash and see if anything is loose..."
I thought had this one myself--until I realized it was just the key fob slapping the side of the column. Just saying.
I had the same dash rattle above the radio, I just popped the trim off and put some window kit( black stuff it kinda looks like playdough, can be bought at any auto parts store) around the clips that hold the trim on and it fixed it, mine seemed more noticable when the heat or A/C was on
Happened to read this post and then realize I was the one that wrote it....anyway here is what I found...
1. Was the linkage on the steering column, above the knee bolster, that connects the gear shifter linkage and transmission cable...there was some slack in it and it was rattling around.
2. Randomly went away..
3. Console was not assembled properly, removed and rebuilt the console and all was well, basically found the front half wasn't clipped together completely when the truck was assembled.
4. Truck came up with a few more problems and was traded....I've now got an 11 Sierra which is of much higher quality! Think I got a bad egg with the 09
Your overdue in changing your signature :thumbs:
Yes long overdue! Seems like I never use my actual laptop which is where my pictures are, always on the iPhone...
What mileage are you getting from your 6.2's? I'm struggling at 12 on 93 Octane. Do these things get a little better with mileage? I'm at 3k
Between 11.5 & 13 on E85 it is pretty consistent
This is 65-75% city driving
I am at 18k and it hasn't changed at all
Same milage as my old 5.3 running 87
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
    • What’s missing in all this is patience and investment in the future. Buy a 170K starter home. Ten years later sell it invest in a more expensive home. Eventually you’ll have a 600K home and pay starter home payments. Buy a starter car. Maintain it well. Save the payments after it’s payed for then buy an expensive car if you desire. Buy a tumbler make your own coffee, pack your lunch. Cook your own dinner. Most importantly take care of your car.
    • People mislead themselves. Statistics are highly useful indicators.   Here's the tie-in to this thread. If an oil sample tests shows a wear indicator of 7 using cheaper ACDelco oil, and a wear indicator of 2 (lower = less wear) using a particular brand of Mobil oil, and wear has a linear relationship with engine lifespan, anyone could assume that Mobil is reducing wear by more than 50% (let's just say a 200% reduction for you red state people trying hard to do math) which leads to increasing engine life by 2x. Perhaps, in a vacuum, by itself, when dreamed by AI.   Yeah?! That's what the statistic is saying, isn't it?   No, it isn't. It didn't come out and say engine life is doubled. That's a very bad assumption, and a case of severe myopia by assuming something potentially untrue about the only data point in focus.   Average cost of a new car is 50k. You bet it is.   The median cost of a new car is more like 35k. Expensive cars are skewing the perception that "average" now means a $50k price of entry for a very average automobile. And that's not true. People who don't understand statistics twist the living heck out of them to mean all sorts of things they don't actually mean.   "Average" new car payment is $1000/month. Yep, it is. And in that number are all the $35k new car buyers who bring significant equity, and the $25k new car buyers who finance the car for a month just to get a rebate, and then pay it off. Know what isn't in that number? All the payments made by people who don't finance a car.   Picking one's own data point (don't have a car payment, never paid $50k for a new vehicle, my house cost $170k, I afforded a middle class lifestyle on $4.50/hr) is just a data point. Just like earning $25/hr in an area where the median home price is almost $1 Million is a data point. In fact, it's a lot of data points given that 80% of the US population lives in/around major cities. They're not idiots; the vast majority of them do it to make a living because that's where the big money is.   The highs have become higher, lows have become lower, and how your personal mileage varies is not truth for an entire country. At the same time you can't NOT acknowledge the data. While it doesn't paint YOUR personal picture, it certainly tints the reality that you also live in, as does your single data point.
    • Glad you had success with it. I did as well, but about 5-6 months later it returned. Tried again, same result. This was after the dealer made several attempts and never even got it to slow down.
    • 3.15 Kroger’s in Montgomery Tx
