Guess I could add some pics of the 2003 I use to own
Here she is still in stock form
Getting ready to go into surgery
initial cut
4/6 drop, 22s, escalade door handles, and a billet grill (not that cheap overlay kind)
Well I might as well add to the list.
2003 Silverado 1500
-K & N Cold Air Intake
-CST Uniball Long Travel Kit
-Fabricated lift spindles
-Camburg Hubs
-Heim Steering Upgrade
-Eaton Locker
-4.56 Gears
-Fox 2.5 x 8" Coil Overs On Front
-Fox 2.5 x 16" Smooth Bodies, with Tig Welded Shock Tower On Rear
-Deaver Leaf Pack
-315/75/16 35" BFG A/T's on Alloy wheels
-Glassworks Fiberglass Fenders
-Billet Grille
-Under-Rail Toolbox
-Pulled Bedsides
-Custom Front/Rear Bumpers
-(3) Hella Race Lights Mounted Up Front
-Race/Chase Radio in Cab
-Double-Din Jensen Touchscreen Head Unit
-Polk DB Audio Speakers all the way around
-HID 6000k Headlights w/ Phillips Ballasts
Currently working on swapping the stock 4.8L for a 6.0L big boy! :P (Check out my thread in Engine and Powertrain Tech titled "Engine Swap")
2003 Silverado 1500
-Camburg Hubs
-Eaton Locker
-4.56 Gears
-Deaver Leaf Pack
-Billet Grille
-Under-Rail Toolbox
-Pulled Bedsides
damn, about how much do you have invested?
There is about 12k invested, plus another 6k for the new engine I'm putting into it this week.
Here is a pic of the new tires went with Firestone Destination ATs, like them alot better over the stock tires. Also went with the American Racing Baja wheel.
Edited by dkj313
2010 LT, has the 6.2L w/3.42 gears. RC 2" leveling kit, I'm working on my tune (lots to learn).
A few days after I brought it home.
Before the RC 2" leveling kit
After 2" kit
where these trucks are built RIGHT HERE IN AMERICA :seeya:
Me doing work on a "ice" pile....
Trucked weigh in at 12980....and got 11 mpg going 60-65.
The day I brought it home last July 2010
Desc. in the sig.
Removed 4x4 stickers and the rear bowtie along with the flex fuel badge, added a few accessories also.
