1997 Sierra Map Sensor Failing?
With 135K miles on my Sierra K1500, I've replaced the MAP sensor about 4 times. The reason for changing it out is because I'm getting a P0300 code (misfire). It's most prevalent when performing a hard acceleration when the truck shifts out of 2nd gear and into 3rd gear (under the most load). I've gotton these codes from the day I bought this truck at 20K miles. In the beginning, the problem was solved under warranty at the dealer by simply flushing the fuel injection system. I iinterpreted these problems were the result of all of the additives put into the gasoline due to emissions in CA. The poppet valves would stick causing this misfire. At about 80K miles and after moving to FL, I installed the upgraded MFI fuel injection system. This helped the problem but did not provide a permanent fix. I've also been religious about changing the fuel filter every 30K or so. The only code ever set was P0300 and this was frustrating because I had a new fuel injection system. So, I decided to change the MAP sensor. That solved the problem. What I don't understand yet is why the ECM does not set a code for a failing MAP sensor? I suppose there could be nothing wrong with it, but the truck runs like night and day once it's changed. My only issue now is that I seem to be changing it out every few years. One thing I don't like is where it is located at the rear of the manifold near cylinder number 8. It seems like it would be better suited mounted off of the firewall where it is not subjected to the temperatures and air/fuel vapors. However, it would not be a simple task to relocate this sensor.
I've been told by a Master ASE mechanic that my fuel pump could be wearing out which would not sustain fuel system pressure requirements. This is definitely a possibility. There is another post on this forum where the fault was in the CPS (crankshaft position sensor). In my scenario, I beleive that the MAP sensor is causing the truck to run lean and not deliver enough fuel causing the misfire. I'm not getting black smoke which would indicate a rich mixture.
Look forward to replies. Thanks!
might be the EGR valve.If you haven't checked the fuel pressure then do that too.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
