Help! Odometer Error
I have a 2003 Chevy Tahoe Z71 with an "odometer error" reading in the DIC. Any ideas if this is related to the faulty instrument cluster? I unhooked the cluster when troubleshooting a flasher error over the weekend and didn't know if this wiped out the odometer or caused the error. Never really noticed the error before. I suppose you need a Tech2 to reprogram? ..or am I looking at needing the dreaded cluster f... fix?!
Have you checked your connection to make sure it is on properly and secure? You might try disconnecting the battery for a few minutes and see what happens. Can't hurt.
Haven't heard of to many issues like your describing. Most have been stepper motors going bad. You may need to send for repair. You can look up Techni-car. They are GMs authorized cluster repair place and can be found in Tampa Florida or Cleveland OH. Thats who the dealership would send your cluster to so you might as well take out the middle man.
Nothing can be done with the odometer using a Tech 2. If the ipc fails, it has to be sent to a local GM authorized electrionic service center for repair. Your GM dealer would have to do that for you, in most cases.
Thanks for the replies.... guess I'll double-check my connection and disconnect the battery, otherwise she's going to the GM shop. I'll let you know!
Anyone ever have any luck resetting the odometer error by pulling the IPC (Instrument Panel Cluster) fuse? Seems there as a reset procedure with some GM models where this works for the dreaded odometer error? Thanks...
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
