"park Assist Blocked" Message On Dic
Its a new 2011 LTZ with 590 miles on it and suddenly it shows a message on the DIC that says "park assist blocked see owner's manual". Well....there is nothing in the owner's manual that I can find that addresses the issue or gets the message off of my instrument panel. My rearview camera works, but my backup warning system does not function.
Any ideas?
It is likely dirt or snow or other muck on the sensors. These are the 4 round disc-looking things on the back bumper. And if your manual is the same as the one I have on my laptop, check page 9-77. :)
I had some similar messages at one time, it turned out to be my hitch that I left in the reciever, removed hitch, and no more messages.
Is your tailgate down?
That will set mine off along with hitting the button to turn it off and or the something in the hitch as noted above.
I get the message after going thru a car wash, something in their soap leaves a film on the sensors and screws them up.. a q-tip and some rubbing alcohol and it's all good..
Mine has done this twice. One time when i was backing up my trailer i got the dic message. The other time is when it was raining real hard. I leave my trailer hitch on all the time when i dont pull my trailer and never get the message.
I leave my trailer hitch in all the time too, but haven't gotten this message in several months. I got it a few times when it was brand new. Haven't changed anything and it seems to have fixed itself.
  • 3 weeks later...
Any ideas?
Well mine is doing this too so that's how I found this forum. I tell you I'll be severely disappointed if I cannot leave my locked hitch in my truck receiver because of this programming done by GM. I can understand if I have a trailer plugged into the harness, but just the hitch seems extreme. Additionally, I don't like the fact that the warning message goes off everytime I have dropped below 25mph and then accelerate past 25mph.
It will and the reason for it going off at the speeds that does is because that is when the module "resets" and looks for it again.
Mines done it randomly, but not enough to justify a dealer trip. I'm going to wait for something else to go wrong before going in for just that :jester:
BTW gentlemen, the park assist system can be shut off, at your request, at your dealer, if you really don't even want it. I didn't check one of the option boxes on my '11 because it came with park assist and considering that I've been driving a truck almost everyday sense I was 16, and I haven't backed into anything yet, I'll take my chances without having it on my new one. :jester:
i dont think it was designed so you would not back into anything. it is a safety device so you wont back over a two year old child sitting directly behind your tailgate.
I'm with you on that one. Next time I go to the dealer I think I'll have it disabled since I really don't trust the beeping anyways.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
