Why Are Newer Diesels Much Quieter Then Previous Years
just curious why there so quiet these days, is it all the emission crap?
i had an 04 powerstroke and 2 05 lly,s and they both sounded like good running diesels trucks i heard a 2010 f350 go by and though it was gas until it got closer. same with the lmm duramax unless your right next to it you cant hear it??
They also don't put out all the black exhaust anymore either, I say its part emissions and part people wanting it to be more like a gasser. :uhoh:
Im ok with trying to gain effeciency.. but i like it to sound like a diesel. like a 24v cummins 96-?
They are definately quite for sure. My buddy has an 08 Powestroke, and even with straight pipe (no cat, dpf, or muffler) it's still fairly quiet. Alot of it I think is in the motor and all the new fancy crap they put on them now. They're just making them a major PITA to work on
I too like most like the sound of a diesel.
However, the odd time that I'm pulling into a park with the trailer at 11pm at night (not often, but has happened but not by choice), I'm glad then that my truck isn't too loud.
I have been told that part of the quiet comes from the better injection systems. They inject at higher pressures and use multiple firings of the injector instead of just one big one each time.
X2
DEWFPO
Pilot injection is the key to quiet combustion in diesels. But there are also a lot of other noises like injector noise which are being supressed on modern trucks through more advanced suppression techniques and materials.
I also was told it is due to the compression ratio of the newer motors being lower????
Most of the noise from diesels is from the injectors. They are much quieter now due to different designs (I don't know exactly what though).
Pilot injection (ever notice how most D-Max's get louder after about 2,000 rpms?), lower compression ratios (in some cases), and better sound deadening.
Yep it is all about the common rail injection and multiple injections. Combustion starts with a small "pilot" injection then fuel is added after intial combustion begins. In some engines it can be as many as five charges, I believe the d-max does up to three including te initial pilot injection.
Hey Diesail, is that a boxer in your avatar? I have 3 of them :sigh:
Yes that was our old girl Chloe. We just recently had to put her to sleep at the age of 12. So in memory of the old girl I choose her for my avatar.
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • As a matter of amusement I’ll leave this conversation with this. Do you beat the government average fuel estimate? Statistics are a guide to me. Not a rule. Someone once said I have to have the last word. If true and possible may be. I’ll blame that on working in a family business.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
