N00b Trailer Wiring Question
ckevroll
I recently got a 2001 Yukon SLE and cannot get power to the trailer plug. I had to actually plug the factory wiring into the receptacle because it had never been used. Both maxi fuses (left and right) are in the fuse box under the hood. I have heard that there is a power wire that must be connected under the hood but I cannot locate it. Can anyone tell me or post a picture of where that is?
  • 1 month later...
OK, I'm in there and my power box does not look like the ones shown. Maybe it is an older style but it is a MY 01' Yukon SLE. Im not seeing the wire for power in the harness either...!?
go here http://www.etrailer.com/faq-cbc.aspx
midway down under Step 2 for 'Vehicles without factory installed 7-way'
You need to remove the outer fuse box cover and you will see both the red and the blue wire as in Picture D in the above link
I found it after taking the cover off. It was already wired but the 40 amp Maxi-fuse was not installed. Thanks for the help!
