Trans Concern
first off hello everyone
i have a 03 avalanche z71 with 115k miles
when it shifts to 2nd gear it shifts fine but a half sec after the shift it seems like it shifts again almost like a jolt forward or a slip an catch feeling but the rpm's dont rev up at all an 2nd gear still seems strong and it only happens at medium accelerate all other gears shift fine an i havent heard any noise anyone have any ideas of what is causing this?
should i be concerned has this happened to anyone else?
thanks
trans is probably on its way out. sorry for the bad news but its not uncommon for the 4L60e to go around those miles.
go to a good trans shop and have it diagnosed
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
