Bigger Wheels And Tires Affect Spedo?
yfzrider
I have a 2010 silverado and im going to put oversized wheels and tires on it. Wont this make my spedo off? and if so can you recalibrate it?
If the outside diameter is bigger, than yes the speedo will be off. A few inches taller tire wont be a big difference. Your speedo can be recalibrated.
Can the dealership recalibrate the speedo for free?
They can, provided the new tires are a size the the truck comes with. For example, if you put 265-70-17 on in place of 245-70-17, the dealer can change the ECM to allow for that. As for them doing it for free? Depends on the dealer and your relationship with them. Mechanics are paid flat rate, they get paid by someone, either you, GM or the owner of the dealership must pay them for their work.
I have a quick question on this. I bought my truck a couple years ago. An '03 Sierra 2500HD. Came with LT245/75R16s on them, which from my understanding is the stock size that came on it... But my speedo has always been a few MPH off... The same 4-5mph mentioned earlier in this thread (which is what sparked my current question). Does this mean that my speedo was calibrated for slightly larger tires previously? If so, how much bigger?
Is the speedo reading faster than you are actually going? If the truck was calibrated with 265/75/16 and now you have 245/75/16 then your speedo would be 2.6 mph high at 70 mph. So your actual mph would be 67.4
Tire Size Cal Just enter the tire sizes and see what the speedo would be off by.
Yes, the speedo is reading high... The truck currently has LT245/75/16s on it. I never really noticed the speedo being off until I got my android phone, which has GPS. The car mode for it has a digital speedo and at ~40mph (gps speed), the truck's speedo is ~43mph... At ~75mph GPS speed, the truck's speedo is right around 80mph... This is all from memory, so I might be slightly off, but those numbers are pretty close...
My truck was the same way from the factory. With the stock 265/70/17's it was slow, which I didn't realize it until I got a GPS. Putting 275/70/17's on it makes the speed of the truck match the speedometer. I think my brother's old 2500HD was the same way. Must be a common problem.
Most speedos are off from the factory, but, it is almost always reading faster than you are going. It is common knowledge around the motorcycle crowd that honda motorcycle speedos are up to 8% off on the speedo. Odometer is usually spot on though. Guess they don't want to get nailed for running the mileage faster than it is.
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
