Top Engine Cleaner
Need to do the oil change over the weekend.  I have 2 cans of Top Engine cleaner spray to use.  I understand that I should spray this into the throttle body with the intake tube pulled aside slightly and the engine running.  I then let it sit for a while.  Then restart and drive.  I was told that the SES light may come on.  Do I need a tool to get this to go off?  Also, someone mentione disconnecting the MAF sensor(not sure exactly where it is).  How/when would I do that?  Thanks for the assist.
if the check engine soon light comes on all you have to do is unplug your battery to reset it and it should go away.  No special tools necessary
Siverado-don't disconnect the MAF.  You're engine won't run without it-there won't be any input into the ECM regarding air temp, airflow, etc.  Just remove the air intake tube from the throttle body, and slide it down about a 1/2 inch-just enough so you can see the throttle plate.  If you keep the intake tube flush against the TB, you're engine will still pull enough air through the MAF to keep it from stalling out.
Fitz.
Actually ran it with the MAF disconnected.  The truck stayed lit and didn't stall.  I also didn't get any codes.  My biggest problem was the fan blowing some of the cleaner around.  I used 2 bottles and probably got the equivalent of 1 into her.  I think the second bottle didn't want to spray due to it being pretty cold outside.
actually, the last thing you want to do is disconnect the battery to reset the computer. why? cause for starters, you clear the RAM(data stored over time on how the engine runs) in which if you live in a state that tests emissions, you would fail emissions testing even weeks after disconnecting the battery, instead, pull the ecm 1 fuse with the key on, that kills power to the "check engine" part of the computer, buts keeps power to the Ram side of the computer, plus you wont lose your stations on the radio!
Excellent good info.  I did find the fuse map yesterday also.  It's amazing what you find when you turn over the EC cover.  Top Cleaner went well with no problems.  With only 39k on the clock I didn't expect noticeable improvement.  She's gotten Techron in the tank religiously since day 1.
So how does that motor run now?  Is there any noticable improvement?
Just a word of advice-I changed out my spark plugs a couple of days after using the cleaner;  you should have seen the crud on them-
And they were the OEM platinum plugs with only 15K miles on them-
Fitz.
If you disconnect the MAF, the PCM should go into speed density mode.  That's the old way of doing things before MAF's came around.  :cheers:
It allowed the engine to run siffuciently at idle, but I probably wouldn't have driven around town with it like that.
    • Thanks @newdude, guess I'll keep looking.  Test driving so many trucks that have obvious things broken, I'm thinking "if they couldn't even be bothered to fix the power seat," what else is broken".   Just drove a 2021 where the power seat motor was grinding/binding and wouldn't do anything but make a terrible sound.   An owner that puts dents on the bumper, doesn't fix a seat motor, and had spotty service intervals (along with missing major services) doesn't give me the best of confidence.   Amazed at the number of people that will finance a $60k+ truck, run it into the ground, then trade with a loan balance (every single one had "loan/lien reported" on the CARFAX at the last year of registration).
    • Not true! I have been runing them since 2006 F250! suspension component that works as a sway bar, a traction bar, and a helper spring points directly to the RoadActive Suspension (RAS) kit. Works as a sway bar, a traction bar, and a helper spring.
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
