I've done my own oil changes in the past, and I think i know how. But it seems liek things might be a little more complicated with the new trucks.
Bought the truck new, and it has about 10k miles on it. It has had 2 "quik lube" oil changes. IDK what oil they used cost me less than $30 for the job. These guys have always done well with my other/older vehicles. Something that killed me last time i was in: the fender had a greasy jacket print on it and you could read the guys name badge on the fender. Never been an issue before.
This is what I need:
Oil types or brands?
Change intervals 3/4/5000?
Is Synthetic worth it?
Are there better filters?
Thanks and sorry for not searching.
Mobil 1 full synthetic and Acdelco oil filter. Change the oil when the DIC says so :thumbs:
And yes, I believe the full synthetic's are worth it. Better lubrication and lower operating temps.
Great answer, thanks. Do models all of these trucks have oil change alerts? My truck doesn't have Fuel mileage in the DIC. (LS Crew Cab)
Just use a good 5w-30 brand name like Valvoline, Pennzoil, Castrol and you will be fine. Most go by the oil life monitor that tells you when to change your oil. Otherwise 5k is a good mileage to go by.
Filters have come a long way. If you just stick with 5k oil changes then an AC filter will work just fine. If you want a better filter then Purolator's Pure One is a great filter.
If you don't mind spending the extra money for synthetic it has it's advantages, mainly in the way of extreme cold temps for better oil flow and in the extreme hot temps since it doesn't break down like conventional oil. It will keep the inside of your engine cleaner and help it run cooler. Also with synthetic you can go longer on oil changes. Depending on the oil you can go 10k miles or longer on an oil change.
Synthetic oils to choose from would be, Mobil 1, Redline, Royal Purple and AMSOIL. Pennzoil Platinum, Castrol Edge, Valvoline SynPower are a few of the others.
That is pretty much it. I'm sure others will chime in with suggestions.
I'm old enuf to have seen the recommended oil change interval go from 10K down to 3K. I'm also a Chemical Engineer, and wonder why, with all the advances in oil technology, the interval is decreasing. I recently met an old mechanic who serviced tanks in Korea during the war. He said that due to the scarcity of oil, he would measure viscosity using his thumb and index finger: If oil there would stretch 1/8 to 1/4 inch, he would only change the filter. He also said that is how he treats his personal vehicles, and has never had a problem.
Food for thought, and I believe in synthetic.
I highly reccomend Amsoil, I switched over last year. It is cheaper to go 5k with synthetic than 3k on conventional oil. My choice of filter is a Napa Gold, which is a rebranded wix filter.
What? I dont think it could be easier (unless it did it itself) Take a 15mm wrench, loosening the oil drain plug, taking an oil filter wrench removing the oil filter and repeating this the opposite way, add new oil and dispose of your old oil properly. Dont even need to jack up either vehicle :thumbs:
stick to changing your oil every 3000 miles or 5000 kms...... twice i changed my oil when the oil life monitor told me to each time i switched it up... once i was running a top brand synthetic and the other just a top brand 5w30.... both times my oil life monitor told me to change my oil after 15000kms or 12500 miles... too me that was way to long...... my truck does 95% hiway driving at 80mph plus... i am not easy on my truck.... hard on the throttle hard on the brake.....stick to old school 5000km oil change intervals.......an oil change is one of the cheapest maintence things you can do,,,,,so why cheap out on it...... change your oil on a regular basis your truck will love you for it.......just my 2 cents...
A lot of the oils are similar with the exceptions of the cleaners and chemicals that they place into them.  There are some differences and braggin rights when you switch between synth and conven oils. If you are going to change your oil on a regular 3K-5K mile basis then conven oil will do you just as good as a synth oil.  If you intend to do a lot of towing, hauling or many miles in between oil changes then a synth might be your better options.  Many oils will advertise that they are 10K+ oils, but you will not find many filters that can support that.  I have seen many people swear by pure one, A/C, wix, boshe..etc and they are all good filters.  Purolator is the company that started it all with oil filters (or at leaast thats what they train and advertise) and everyone else is just improving on their technology.  Pure one filters are great and hold up really well, but they are not rated for 10K mile oil changes.  Neither is Wix, A/C or even castrol or Mobile 1 filters.  I attended a presentation by mobil 1 and castrol about a year ago and both companies showed data indicating the performance of their oils and how well they performed (this was on the mobile 1 and castrol edge brands).  Both did great and both groups admitted that they did not have a filter on the market that they recommended to run the entire time of the oil rating.  In fact, if I remember correctly, the castrol rep said that they actually used a mobile or a purolator filter (I could be wrong...been a year or better).<BR><BR>Anyway long story short.  Every oil/filter has is pro's and it all depends on how you drive and more importantly, what you are comfortable with.  I am not comfortable driving 8-10K miles between oil changes.  I do not care if the label says that it is ok.  I will change my oil at 5K intervals or even before if I feel like there is a need for it.  <BR>
Are all of the synthetics rated/approved for what the new trucks need (dexo)?
Mobil 1 (both regular and extended), Pennzoil Platinum, and Quaker State Ultimate Durability. All top tier. Used oil anaysis on Bob Is the Oil Guy recently seems to look favorably on Pennzoil Platinum, but none of these choices could be a bad one. You may or may not see packaging with the Dexos symbol on it yet, but all three brands currently are dexos approved.
Wix, Napa Gold, Purolator Pure One, or just a good old AC Delco PF48 (can be had for not much $$$ at Wally World) will do a good job for you filter wise.
List of dexos approved oils
As for me I used Pennzoil Platinum on my first change. I plan on changing every 5000 miles. I may look at the Quaker State Ultimate Durability in the future as it is also, like Pennzoil, a Shell Oil Product and has great used oil analysis numbers on bobistheoilguy. It's also a bargain at Wally World for $19 for a 5 qt. jug. I wouldn't hesitate to do Mobil 1 either as I've used that in previous trucks....great oil. Again don't think you'd go wrong with any of these.
DIY Oil changes are the best. What's better than working on your truck? Don't forget to buy a grease gun for the two zerk fittings (one on each controller arm). Those should be checked every oil change too. And for the love of god buy a good floor jack and jack stands.
My DIY syn oil changes cost me:
$24 - 5 quart jug of Pennzoil Ultra
$6 (ouch) - 1 quart of Pennzoil Ultra
$6 - Wix oil filter
Total = $36 (not bad)
Mobil 1 full synthetic and Acdelco oil filter. Change the oil when the DIC says so :jester:
Your truck should have the oil change reminder. With the truck off turn the key to on and pump your gas pedal 3 times. You should see Oil Life Reset start flashing in the area where you normally see the odometer.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
