SpartanAutoworx Posted September 29, 2016 Posted September 29, 2016 Look in the glovebox for the rpo list. Look for NR3 or NR4. I believe one of them is the RPO for the Borg Warner Case.
Jordan Oliver Posted February 16, 2019 Posted February 16, 2019 Really easy check here: https://driving-tests.org/vin-decoder/.
KMGZ400 Posted June 21, 2019 Posted June 21, 2019 14 hours ago, planedr said: So, Is it??? Well the post is from 2011 so I would hope that he figured it out by now
dsr611 Posted June 21, 2019 Posted June 21, 2019 3 hours ago, KMGZ400 said: Well the post is from 2011 so I would hope that he figured it out by now Not only that, but the OP hasn't been on here since Oct 2015
Joanne Posted January 6, 2020 Posted January 6, 2020 So I know this is an older post but I’m looking at a Denali truck and I found a 2012 has AWD and a 2015. Which one would be best to go with? It will be fir daily driving, and down the road for towing a small trailer. is it better fuel economy with the AWD in the 2012 year? Thank you!
DJG Posted March 16, 2024 Posted March 16, 2024 For all you so-called experts here, if it has a front diff or front axle shafts, that does not mean it has AWD! That means it has 4 wheel drive, not necessarily AWD. It could be either. So having your wife look under the front for a diff, would not answer the question. Stop being a nasty know-it-all when you really do not know what you are talking about.
