How Much Abuse Can Ifs Take?
I was watching some truck show and they were rebuilding a tacoma and they actually made IFS sound beefy and durable...so i have to ask...
1) how much abuse can is really take before it begans to break? woulden't road imperfections and bumps take a big toll?
2) how well does it stack up against a solid axle front end?
3) why did GM ditch the solid front axle?
Gm did away with the solid front axle because the buying customers and the competition required them to do so.
The Solid Front Axle is old school and full Independent Suspension provides better ride quality and steering control.
Solid front axle is tough on tires, ride quality, stability, and weight. They did away with it to get better tire wear, better ride, better stability, and lower weight. Solid axle generally means higher ride height as well.
well my 2007 2500HD 6.0L Silverado work truck handles daily abuse. i drive it off road every day on rough roads, and i never go less than 25 mph. haven't broke anything yet.... knock on wood!
dodge and ford are on a form of solid front on their heavy duty trucks why isnt GM?
well thats just it everybody tells me IFS is weak but ford and ram both offer solid front axles...i just don't get it
IFS is more than adequate for what 95% of drivers do. IMO its actually pretty tough. I hit a mud hole so f'ing hard that it should have broke something, i mean it made a LOUD noise and i figured i broke a tie rod but it didn't break a thing. I think its a bunch of BS
IFS can handle a lot. and you can get plenty of stronger aftermarket parts that REALLY beef it up to be just as/stronger than solid axles.
Stock vs Stock Ifs is better IMO, it has better grounds clearance(on top of what has been disguised) and i wouldn't hesitate to say it is just as strong. But when you modify it by lifting it is when it becomes weak and then the solid axle becomes better. Just depends on what you wanna do with your truck.
Unless you want to install a front locker or go rock crawling, don't worry about IFS strength. Any downsides for it are outweighed by the benefits for 99% of the driving most of us will do.
solids are better offroad though i will say
Not really, solid front axles will hang up in the mud or tire ruts due to axle clearance and push the mud where IFS dont and when the left or right tire gets up on something the other tire will ride on the edge of the tire reducing traction where a IFS wont, think about it the H1 Hummer and offroad race trucks have IFS but our trucks are no where as tough as that suspension but the set up is the same.
Offroad, Ill take the strength and simplicity of a solid axle. For the other 99.5% of the time, IFS please, ride comfort, no death wobble and better steering feel. Anyone whos actually gone offroading will tell you its a hell of a lot easier swapping an axle shaft than a CV axle.....especially when the truck is caked in mud. Overall, for light wheeling, IFS is ok, just dont try to steer out of ruts too hard or hit stuff with your wheels turned or rockcrawl.
    250.3k
    Tiffanyrose
    Tiffanyrose
  • Who's Online   2 Members, 1 Anonymous, 954 Guests (See full list)
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
    • I would not argue that with you. It would be pointless to argue against the truth and you speak the truth.    My question and in fact the entire point of this thread is an exploration into the levers of wear which happens no matter how well we maintain our powertrains.    Some of these levers we exert a good deal of influence over which can and do result is lower wear, longer powertrain life. Some others we are sort of stuck with.    An engine is typically done when the ring to bore seal no longer is able to do the job effectively. Normally the first thing to go in a engine otherwise well maintained and adult driven is this seal.    Looking into the means, methods, products and attitudes that influence the rate of wear seems a worthwhile inquiry to me.
