Protection For That Plastic Tailgate Cap
i got off work early and was pretty bored sitting at home alone... but then i thought, "i wish that plastic tailgate cap had bedliner on it like the rest of the bed to cover up and prevent scratches!"
well last weekend i remember seeing a commercial for that Duplicolor Bed Armor Spray. and i went to the store looking for some. didn't find any, but i did find a can of Rubberized Undercoating. i figured, what the heck that cap is only about $50 to replace if i royally screw it up.
i used an entire can of DupliColor Rubberized Undercoating = $5
i put about 3 coats on, the first 2 coats were light coats, the last one was a thick coat (moved can at a slower speed). if you attempt to do this, be sure to keep the speed, angle/orientation of the can, and distance from the part constant! any change and it will look un-even. its just like normal spray painting!
well here are some pics of it drying on my porch, it looks pretty close to the spray in bedliner i already have:
i'll post pics of it installed once it is dried.
Interesting, Looks good!
Mine is pretty beat up and have a brand new one in the package still. Maybe I will play around with the beat up one. The bed armor stuff is some good stuff. Used it on my hitch basket.
i put it on the truck to let it dry over night. the color is more flat than glossy like it was when wet. the bumps smoothed out a little, but still looks good.
i think the spray can bed armor stuff would have been a better choice, but didn't find any in stock locally and didn't feel like ordering it. but overall i'm satisfied. its rubbery feeling and has some cushion and skid resistance to it.
here is what it looks like dried and installed:
Looks good! I took the tailgate cap off mine and threw it in the trash before I had the bed sprayed. Did the over the rail and covered where the tailgate cap was with bedliner.
must be nice... when i took the cap off, there was some big giant gaping holes across the handle side of the tailgate, hidden by the cap.
alright, so it didn't hold up as well as i thought it initially would. looks like a bird walked on it yesterday, left a couple of gouges from it's feet in the undercoating.
i guess it's time to order a new one and have my buddy spray it with bedliner stuff!
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
    • I have a 2026 base 1500 "WT" regular cab with basic Chevy "Infotainment 3" 7-inch screen/radio. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit]? [I listen to classical and it gets a bit raspy at slightly higher volumes. Don't need a sub etc.] Do I have two or 1 speakers in the doors? etc. Thanks Bill  San Jose
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
