Rough Idle/engine Knock/service Engine Soon Light Came On
I have a 2001 2500 hd with the 6.0. It has 200,000 miles on it and just today it was idling rough. After an hour of driving it at a stop light the service engine soon light came on then went back off as i went. It was rough in park /neutral/ and drive but would go away once under load. Then i started to hear a knocking/pinging from the engine at idle. it speed up and slowed with the rpms. i took it strait to a shop. They said the codes showed that i had over 2000 misfires. They removed the valve covers and said everything there was fine and that they were going to have to take off the intake to see whats wrong. Are they doing the right thing? i dont want them to charge me a fortune if its just an o2 senser or something like that.
Unfortunately, you will probably get bent over the counter and taken advantage of over this, they might chase a ghost bustin in that deep, seems like somethin more electrical to me rather than internal, but I dont take my word over theirs.
I might have taken a look at the spark plugs?
I would normaly try to fix myself but i was 70 miles away from home and scared to drive it any further. the place i took it to is a nationaly known rapair shop so i would hope they wouldn try to "bend me over" i would assume they had checked the most obvious things like plugs and sensors before they removed the intake.
yeah, how old are the wires and plugs? Maybe that simple. And don't assume. Ask them about obvious things like the wires, plugs and coils.
200,000 miles old. They havnt started anything yet. I will call in the morning to ask the obvious things. This problem happend after i drove for 7 straight hours. i have heard alot about piston slap on this forum. could this be that? im just arming myself with as much knowledge to tell the shop tomorrow so they look for the right thing.
There will be codes to point them in the right direction. Have them tell you what they are and what the fix is. It might be simple, maybe not so.
Mark
They knew what they were doing. Busted push rod. $1000.00. That's with oil change coolant change. New plugs / gaskets
Thats good.
Well spoke a little to soon. they showed me all push rods and springs and a few more were broke or bent. There replacing them all for 500 more. I said do it. Oh well might as well replace them all. Can't complain with this being the first major problem at 200,000 miles
Glad it turned out well, "shops" sometimes go to town and charge you crazy when something simple would have fixed it. Going off a misfire could be something simple, sounds like they knew what was going on.
Well they dug into it a little further and my cam was chewed up too. Getting an engine put in. There just charging me for a used engine with 70,000 miles and 9 hours of labor. Seems fair. It's all under 3 grand. Cause is most likely running low on oil. I had a real bad oil leak but just added oil between changes. Guess it got too low a few times.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
