Aftermarket Radio messes up DIC?
Tobes
I just read that because some of the systems of the DIC work through the sound system, that putting a different radio in the truck would mess that up....Have any of you heard of something like that?  That sounds really messed up.
Thanks
sounds fishy to me
we'll find out soon,  I'm gonna put my pioneer gm sized player in the trailblazer when I get a new pioneer mp3 player for my silv.
The OnStar system was linked to the radios used up to the '02 models.  Replacing the stock radio on these requires an aftermarket adapter to keep OnStar.  The '03 radios actually are actually tied to the body control modules (BCM).  This means that any changes (aftermarket radios, etc.) will require the module to be reprogrammed (just like the fog lamps).  This was done to aid in theft prevention of the radio.  The radios in the '03 require the VIN to be programmed into the radio at initialization.  If changed to another vehicle, the radio must be reprogrammed by Delco/Delphi to reinitialize.  I just wonder how many people are going to be screwed over on ebay when buying the '03 take-out radios. ???
  • 3 weeks later...
What's the question......  You can plug and play the 01-02's headunit but you will loose onstar.  No sweat, if you don't use it, I just went ahead and bypassed it.
  • 3 weeks later...
Is there anything else effected by this?  I heard that it may effect the resetting of the oil change light (I was told that some reset thru the ignition/gas/break pedal combo of some sort, and some go thru a radio button combo).  Anyone else hear anything like this?  I really want to put my JVC in the truck (the kd-sh99, it does mp3-cdrs), but I don't want to sacrifice any saftey (if changing the stock HU causes some warning to disable)
Here is just a little more info for you guys on the Data II Series radios found in the '02-up TB/Envoy/Bravada and '03 Silverado/Sierra/Tahoe/Yukon/Suburban/H2.
Class 2 Data Vehicle Concerns
Metra's 70-2003t and 70-2003
Applications:
CHEVROLET - 2000-01 Cavalier, Impala, Monte Carlo, and Venture. 2001 Malibu
GMC – 2002 Envoy
PONTIAC – 2000-01 Sunfire and Montana. 2001 Aztec and Grand Am
OLDSMOBILE – 2000 Silhouette and 2002 Bravada
Note: The 2001 Venture/ Montana/Silhouette do not require the SP-2003 chime module.
Metra’s 70-2003t is a 15 foot “t-harness” that will allow the installation of an aftermarket radio while keeping the factory radio (somewhere accessible) in the vehicle to retain “vehicle customization”. This is required because the radio is used as a control panel to communicate with the vehicles computer for the customization of certain “convenience features”. All features work and remain at current settings with the factory radio removed, but can only be customized and/or reset by an authorized service center. In my belief, the door chime is the greatest loss, which is inoperative without using the 70-2003t in conjunction with Metra’s SP-2003 chime module (self enclosed speaker) mounted under the dash. This will keep the chime to its factory settings. Metra’s 70-2003 can be used instead, but the factory door chime will not work.
There is also no switched 12vlt. power supplied in the radios plug, so it will need to be sourced somewhere else such as the factory fuse panel. A 15 to 30 amp fused accessory power source is recommended. Depending on the vehicle there are several choices in the factory fuse panel, such as the sunroof or windshield wipers. Both the 70-2003 and 70-2003t include a 42” red wire with a fuse tap at one end.
Vehicle Customization Menu Options: (Most Cavaliers, Sunfires and other base models do not offer most, if any of these features. Check the vehicle owner’s manual to see available features.)
Displays current settings
Oil life monitor reset
Tire inflation monitor reset
Delayed headlamp illumination
Automatic door lock and unlock
Remote visual/audible verification of remote lock/unlock
Enable/Disable content theft
Enable/Disable trunk lock shock sensor
Short or long horn with remote lock/unlock
Key fob transmitter programming
For the Cavalier air bag concerns:
GM’s service document numbers 537803, 558212, and 558208 give detailed instructions
on removal of the radio. Document 537803 is the basic removal and installation referring to 558212 for the trim plate bezel replacement, and to 558208 for disabling the SIR system. Not suggesting things shouldn’t be done to procedure, but I‘ve spoken with a handful of GM service techs and not one follow these procedures when removing a radio. Do you disconnect the negative battery terminal before any install?
Other:
There is another group of vehicles using class 2 data. The Oldsmobile Aurora, Buick LeSabre and Pontiac Bonneville use a flatwire or ribbon cable type connection @ the radio. This is also referred to as GM’s “dock and lock” setup. Until a harness, in my opinion a complete rewire is easiest for aftermarket head installation. Cadillac also has several models using class2 but further info is not yet available.
  • 3 weeks later...
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
