4 way headlights
I did some "fiddling" with this last night & figured out how to do it without spending anything.  I used 2 small pieces of wire & a diode that I had at home.  OK if you were doing this it may cost you a buck for the diode from Radio Shack.  Here is a pic of the temporary setup I made:
http://www.home.earthlink.net/~smckitt/relays.jpg
On the fuse box cover it shows which relays are for the high & dim lights.  I also discovered that the negative is what is switched, not the positive.  I located which pin on the relay is the one that is switched, this happens to be pin 85 (I think) on both relays.  So I simply wrapped the wire around that terminal on both of them & put the diode in the middle.  The diode allows current to only go in one direction.  So when the dims are on the current cannot pass to the high relay, but when the high is on the current will pass to the dim relay to energize it & turn them on also.  I did this in about 10 minutes so it is not real pretty or "safe".  I will find what the current is through this diode & decide what size wire & diode is needed.  So now I am thinking if this can be done, then the DRLs & fogs could be done in a similar way.  Hmmmm.....
Scot
Well I'll be...........that looks like it may work pretty well. As long as the diode or wire doesn't melt. Maybe figure out a little safer set up and I'll give it a try.
I will, that was just my proof of concept.  I am going to measure the current, & from that use a larger diode & wire if necessary.  Also add some heat shrink tubing & maybe some type of connector to ease installation & removal.  Will keep you informed.
Please do follow up on this.  I am VERY interested in not only the 4 way headlight but also the Fog lamp on with headlights and Fog lamps stay on when hi-beams are activated.  Keep us informed.
Thanks for the hard work!
Ok I'm new at this forum thing and posting stuff, here it goes, I was looking at the 4 head lamp conversion thing myself, but it it is that easy then great. If you can keep us posted on how the final job turns out. It is always a good thing to save the cash for the bigger toys.
Nick
I will keep everyone posted on what size wire & diode to use.  I am guess the small wire & diode I uses will work fine.  Afterall the only amount of current used is to energize the relay, not run the lights.  As for the fogs on also.  Do it the same way.  Run a wire from terminal 85 on the high to the terminal that energizes the relay for the fogs.  Not sure which that is yet because there is 5 legs on it, not 4 like the other two.  It will then be setup to run when you turn the switch on from inside & will then be on all the time when the brights are on.  Holly cow, 6 headlights on for bright.  And all for less than $5 & a little time wiring it up.  I may see if I can make some of the wires up at work (Delco Electronics :-)) & sell for what $2 a piece or something.  Will let you know.
Later,
Scot
Great news Scott (and perfect timing------I just ordered and recieved in the mail TODAY the R & D head light controller)   Do have a question though.   Can you run that wire off of the #85 terminal on the hight beam relay to any kind of relay to activate it (to turn on some other add-on lights)????  ???
Bandera,
I don't see why you couldn't.  Just remember that terminal 85 is a ground not a "hot" (12 volt +), so wire you setup accordingly.
Later,
Scot
I don't know what the part number is on this one.  It is one that I had here at home &  just used it to see if it would work.  When I make it "better" I will tell you what size diode I use or a P/N so you all can find it too.
Scot
Scott any idea what the current is on those relays?
I see at radio shack they have a 1.0A and 2.5A diode, just not sure which one is needed.
Checked out my truck today---VERY CONFUSED!!!!   I opened the fuse box under the hood on the left fender and had a picture of your set up to compare.   Only problem is mine is much different from yours.   I only have three of the larger relays (3614) and four of the smaller ones (8567).   On the label on the lid it list one of the larger relays as "HDLP" which is for the headlamps.  The other two are labeled "IGN1" and "STARTER".  On the label it shows another large relay for "R/R DEFOG" but my truck does not have that.  Also I might note that my truck did not come with factory fog lights.  There is only one relay for lights.  By the way mine is a 2000 K-1500  Z-71.  What year is your truck from which you show the picture?  Mine has fuses in different places than yours and the main fuses along the top part of the picture are different.  I would still like to figure out how to make a relay come on with the HI beams.  Since I had already ordered the R&D headlight controller, I went ahead and installed it today.  Works good.   :eek:
