01 SUBURBAN CONSOLE EXTENSION
I HAVE A 2001 SUBURBAN LS THAT HAS FLOOR CONSOLE,BUT DOES NOT HAVE EXTENSION BETWEEN FLOOR CONSOLE AND DASH.HAS ANYONE EVER ADDED THIS OPTION? IF SO IS IT EASY TO DO YOURSELF.DOES IT COME FROM DEALER WITH YOUR INTERIOR COLOR OR DO YOU HAVE TO HAVE IT PAINTED?THANKS
DOES IT COME FROM GM IN THE COLOR YOU WANT? IS THE HOLE FOR CASSETTE PLAYER IN ? I DO NOT WANT CASSETTE PLAYER.THANKS
STILL WONDERING DOES IT COME FROM GMDIRECT IN YOUR INTERIOR COLOR?AND IF YOU ARE NOT GOING TO HAVE CASSETTE PLAYER IS THE HOLE ALREADY THERE ARE NOT?
if you don't have the remote tape or cd player there is a cubby hole that goes in there.  The install is a snap.
This pic may clarify things a bit more, between the two pieces there are two screws that can be accessed by removing the cupholder tray.  Very easy install.
And yes, they come in your interior color, just make sure you get the correct part number.
Drop bill an email at http://www.partszoneonline.com/
Will that piece fit with the floor mount manual four-wheel drive shifter? I'm guessing no but you never know!
Don't be so quick to doubt.
I think my truck was the only one in existence w/ the floor mounted shifter and a full console.  It took a little customizing work, but I was very happy with the results and it looked factory.
I installed the rear half, then I notched out a bit of the front half and kept going back and forth to get it just right for full movement of the shifter.  Before I installed it I put a piece of the black door edge gaurd on it to give it a clean look.  I was more than pleased w/ the results.
That is a nice looking photo on the console there Jon.
I originally was going to install the rear portion, but then I looked at it and got to thinking....  long story short, I made it work :D
That's what it's all about.  Keep picking up a few things every so often along the road of truck ownership.
