Crank Re-learn Needed ? What Is It ?
Hi All,
I changed out a faulty Crank Sensor and the engine fired right up and idled a little rough..but then after driving ~10 miles in stop/go traffic it settled down and is running better....question is...what exactly does the dealer do on a crank sensor re-learn...is this a computer thing or do they just drive it around doing stop and go ??
02 Silv 1500 5.3 Z71
TIA...
Jim
it's a computer thing, the Tech helps the PCM learn the Crank Shaft Sensor positions.. takes all of about 10 minutes, but dealers bill in hourly increments with a 1 hour minimum.
Thanks for the link...
has not thrown any codes since the new sensor install...not even the dreaded P1336
EDIT:
Is a crank re-learn needed after crank sensor replacement if it doesn't throw a P1336 code ???
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
