Towing Capacity
craigsz71
hello everyone i have a 2010 z71 and am looking at getting a camper the weight of 5020lbs empty can my truck pull this safely? i believe i have 3.08 gears to by time i add stuff for camping im prob looking at 6000lbs thanks
  • Replies 58
Are you sure about that 3.08 gear ratio? Most Z71 4X4 trucks with the 5.3 engine and 6 speed automatic transmission come with 3.42 gears. Or is this a 2WD truck? Anyway, you should be fine if you have a factory tow package with an external transmission cooler. I recommend you check the official tow rating for your vehicle though.
It will be okay. Maybe a bit better than older 4-spd trucks with 4-spds and 3.73. Use Tow/haul mode, lock out 5th and 6th gears.
thanks for the quick response guys the window sticker say 3.08s yes its 4x4....... the z71 has the towing package right... it came with frame mounted reciver hitch
Z82 is the towing package and KNP is the aux trans cooler. Z71 is just skids,shocks and decals.
sorry about that being in wrong fourm.... was kinda in a hurry needed to know if it was to big or not. because going to look at it soon... so what do you think ryan
You will be really pushing the envelope. The issue really isn't the tow rating. You need to check ALL of the ratings. The most important is your GCWR. You also want to check your payload rating, axle ratings and tongue weight rating.
My guess is, you may not have the tow package on that truck if you have 3.08s (that would be really weird). I think that the tow pkg comes with 3.42 or 3.73 (I may be wrong). If you don't have the tow package, you will need to install a good trans cooler. I would recommend a stacked plate cooler with a pusher fan (especially with 3.08s).
Your biggest challenge may be the trailer tongue weight. You will definitely have to have a WDH.... The trailer tongue weight must be over 10% (between 10-15%) of the loaded trailer weight to avoid swaying. That would put you over 600#. Add that 600# to the passenger and cargo weight in the truck and you may be close to or exceeding your payload and/or rear axle rating. Also check the weight rating on your tires.
Here is a good place to check out your #s:
http://changingears.com/rv-sec-calc-trailer-weight-tt.shtml
Right off the GM website, 7000 lbs :rolleyes:
"Max Conventional Trailering, 3.08 Rear Axle"
so than im golden :D
the camper is a 2000 dutchman 30' for 3k obo i looked them up and they sell for around 8k :D
Tow ratings, on there own, mean very little. Basically, they tell you the MAXIMUM amount of weight that the vehicle can tow EMPTY. That means zero passengers, zero add-on accessories (like a shell or bed cover) and zero cargo. I don't know about you but that's not the way that we go camping.
It's important to read your "Owner's Manual". It explains all that stuff in there. Taking one comment off a website (that was not intended to tell you that you are "Golden") to justify towing a rig that size with a 1/2-ton PU may be just looking for trouble.
no need to be smart about it im new to all this and was looking for help from ppl with experince........ and i did read the book but dont make since to me so sorry i dont understand all the weight factors and again was looking for help from ppl that have been there done that :rolleyes:
also how do i find out if mine has towing package?? is there some type of sticker or marking to look for thanks again for your time guys
Sorry if I seemed to be getting, "Smart about it". That wasn't my intention. I left a pretty informative post for you and I was just a little shocked at your post about being "Golden". I don't think that was the intent of the person that gave you that info on the 7K# tow rating. Trust me, you are far from "Golden" with a 6K#+ trailer on a 1/2-ton pick-up. You'd be very wise to check-out the website that I posted.
I'm not saying that you shouldn't tow that trailer. I'm just saying that you shouldn't think fr one minute that you are "Golden". I think if you do your due diligence, you may find that you are either pushing the limits or exceeding the limits of that truck. Just having that knowledge is very important because it may effect that way that you drive with that trailer. Just having that knowledge could save your life and others.
Evidently, you have the window sticker from that truck. If it has a tow package, it will state it.
You can also look at the RPO listings in your glove box. If it has "Z82" listed, it has the tow package. If it does not have Z82 listed, It doesn't have the tow pkg.
If you look in the glove box at the tag, it lists all the RPO codes for your vehicle. It will tell you everything you need to know.
Also, by entering your VIN number here, you can get all the details as well.
http://www.compnine.com/vid.php
I believe your within your trucks towing range and it should do just fine. But.. you'll be at the top end of it. With that said, make sure you have a good e-brake controller like prodogy along with proper weight distribution hitch and sway control.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
