Disable Electric Door Lock Buttons
Craig1947
My little dog likes to dance around on my door switches when I leave him in the 2009 Sierra. I can handle my mirrors going in and out, but when I'm pumping gas and hear that click/honk, and see him grinning at me through the window, I'm not too happy. And On-Star doesn't work under a station canopy. He also can unlock the truck the same way, so I never know what is going to be left when I return :fume: I would like to be able to put a switch somewhere on/under the dash that I could use to turn off the switches on the door, without deactivating my remote entry or throwing error codes. Any ideas? I know I'm not the only one with this problem - or am I? Oh Yeah. I could pull the keys every time I gas up, but sometimes I forget. That doesn't help when he unlocks it, anyway.
the power lock switch is disabled if you lock the doors with the key fob remote, might just get into the habit of taking the keys with you and locking the doors with the fob.
at that point only the fob will unlock the doors without the alarm going off. Key or pulling up on the manual lock will set off the alarm, and the power switch is completely disabled.
You could also just leave the window down enough to reach in and unlock the truck. I do this regularly as I have been locked out in my own driveway by the dog as well.
You're are so right. It was another vehicle where he unlocked the door. Still, if I don't always grab my keys, he can and does lock me out. I try to remember to take the keys when I gas up (the only time I wouldn't remove them), but I'm gettin' old and dumb(er).
lol, no worries.. I used to do the same (leave the keys in at the pump) but no longer, too many wackos in this area.. awhile back I was pumping, and went in to get a bottle of water and came out to see someone grabed my nozzle and was filling their car on my dime..
Thanks for the understanding. I'd never leave the pump with the keys in the ignition, even in good ol' mid Michigan - surely not in SoCal.....HA I guess I'll probably learn to live with it, and keep a key in my wallet. Nice forum here. Think I'll stick around!
So nice to know I'm not the only one :fume: I do try to leave the window down a bit, except when it's 15 below. I suppose if I had a switch or something, I'd forget it as much as I'd forget to take my keys or leave a window down.
What kind of gas station are you getting gas at? I can make OnStar work in a concrete parking garage. It's the same exact thing as a cell phone so you should have no issue getting service.
:fume:
I checked it again, and it does work. It must have been having a bad day the one time I tried it a couple years ago. Actually, it works better than my cell phone service :(
He was the last one using the pump, it is his dime now, unless you prepaid. If you did not prepay, drive off. Let him expain the gas and go.
XM cuts off under the canopy. Why dont you put a locking gas cap. Force yourself to take the keys -- problem solved.
XM uses satellites. OnStar uses cell towers for vehicle communication which will work just fine in most covered areas. Hell, in some of the Boston tunnels I think they have cell repeaters down there.
    • That dog don't hunt. 😏   First, a 2025 with 12K on the clock AND idled for a year nonstop is false on it's face; this is 2026. You can do one or the other but not both.    Second, ENGINE HOURS are absolutely available. The rest is third grade math. Micky Mouse scanner he got out of a box of Cracker Jacks OR an ID10T error.    Third, if they ran it out of oil "Several times" that motor is boned on the first hit.    Does this guy think piling higher makes it stink less?
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
