2011 2500hd With Truck Cap Pics?
Looking to see if anyone has any pics of the newer HD with a low profile, sleek truck cap?
Im selling my 04 that i bought new and havent really paid attention to any of the trucks accessories until now
Dont necessarily want a cap , but it helps immensely for my business since I just sold the company van also for the down payment.
Trying to keep the payment as L
O
W
as possible.
Thanks
I know it's not an HD, but here's some pics of a Leer XQ that might give you an idea....
Thanks for the pics...How do you like the LEER cap?
Looks good on your truck and I just happen to be going Black as well
I dont have a 2500 but I have been thinking about a cap too. I like the look of a truck without a cap better but a cap would make mine more usable. Leer makes a great cap. Had one on a tacoma I had in the past.
Just picked up a Z series ARE. Love the cap. Would have been nice when they did the turbo liner on my truck if they didn't go over the body so much on the sides now that I have the cap on. The whole idea of this style cap from ARE is to give the truck that suv look. But I'm happy with it no the less. Was just under 2K for this cap. Has 2 dome lights inside. High mount led 3rd brake light and the window between the cap and truck folds down for easy cleaning between the truck and cap. Also has the slam latch on the back.
Thanks for the replies...I pick up the truck Thursday...
Also trying to decide if I should go bigger on the tires...like a 295?
It has 265 70 18
Going to do a search and see who is running what
Thanks Again
  • 3 weeks later...
Sorry, didn't see this earlier.
Love the Leer Cap.
Have had no issues with it at all, aside from a boat falling off the roof rack and scratching it...but that was more my fault really.
It is VERY dark to look backwards out of, and you are somewhat limited with what can fit in it, if you had been used to having an open bed truck. It does a great job of keeping things secure & dry though. I would definitely spring for a fold down or removable front window & lights inside.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
