Its Finally Happened!
  • Replies 36
It is not 5k and a raise, just because you read it in the paper does not make it true.
  • 5 weeks later...
I thought this post would be about how they were going to reopen the truck plant at oshawa :lol:
Wouldn't that be nice.
16,000 jobs in Oshawa @ GM plants in the 80s down to about 3,500 (I think) presently & less when the current Impala production ends.
Lots of frames, engines, transmissions, transfer cases were sourced in the US.
BTW, GM has been assembling vehicles in Canada since 1918.
  • 4 weeks later...
Well everybody, we FINALLY know what the first vehicle is: the Chevy Equinox! I guess since they are selling like Molten Hotcakes, CAMI and Oshawa are at capacity and can't keep up with demand!
Sent from my BlackBerry 9330 using Tapatalk
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 805 Guests (See full list)
