Noticed 5.3l Has Rough Idle At A Stop Light
I have a 5.3L '07 Seirra new body style......i've been noticing that when i'm at a stop light waiting for it to turn green my truck has a bit of a rough idle or miss it seems....tried new plugs, plug wires, good gas....any ideals?
I just had this but I see you already replaced plugs and wires. Mine was doing the same thing and I replaced my E3 plugs with the factory AC Delco iridiums, changed the plug wires and I cleaned the throttle body with sea foam deep creep. it worked its been a week and so far no more miss at idle. I wish i would have done one at a time to see what the culprit was. I have 76,000 miles on mine and the throttle body had a film of dirty oil on it. i took the throttle body completely off and sprayed alot of Sea Foam in the intake. I let everything sit while I changed the plugs and wires after hooking up and reinstalling everything it fired right up. I was told that if you disconnect the throttle body before cleaning it you wont have the idle relearn problem that takes alot of miles to accomplish! I heard that you should never touch the throttle plate in the throttle body while its plugged in. I have heard of alot of other things that fix this issue too so hopefully someone else will chime in.
i would put money on it, if i had any.. :cheers: it was the E3 plugs. a lot of people have had issue misfires, rough idle after installing them. LS motors just don't like them. stick with AC Delco plugs/wires..
I have the same issue on my 2000. Would any parts place have that sea foam?
Yes. Autzone, Advanced, etc...
i get mine at WalMart. a bit cheaper than the auto parts stores. sometimes almost $2.00 :cheers:
Noticed the same problem in all 3 5.3L trucks I've owned, a 99, 07 (brand new) and 05. Throttle cleaning and sea foam and new plugs and wires and other stuff never did cure it, I just learned to live with it. Seems to be normal.
i would put money on it, if i had any.. :) it was the E3 plugs. a lot of people have had issue misfires, rough idle after installing them. LS motors just don't like them. stick with AC Delco plugs/wires..
Lol, yes the E3 plugs were the culprit. After putting the iridiums back in my fuel mileage went up too. Its funny these engines run perfect and they don't need fancy plugs!!! Just the factoru iridiums!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
