Replacing Low Bean Bulbs In 04 Sierra
I'm thinking about getting a set of these silverstar bulbs for my 2004 GMC Sierra, is there anything special I need to do to install these?
Also I've read in some of the newer trucks you've got to dissemble a lot of the grill to replace the bulbs, not sure if that's true but does this hold true for 04 models?
No nothing special. Easy swap. On an '04 there are 2 pins that hold the headlamp assembly. Turn those and pull them out and the assembly comes out.
bulb replacement is as described above. as far as the silverstar headlights, i strongly recommend saving your money. i put a set in my truck, and saw little to no change, and they burn out much quicker then a standard bulb. the passenger side bulb only lasted about 10-15,000 miles or 6-8 months. they had a 12 month warranty so i exchanged it for a new bulb, but IMO they are not worth the money.
In your GMT 900 truck they probably would have a shorter life since the low beam bulb is also your daytime driving lamps. On my 800 I've had the SS Ultras for over 4 years and about 60k and still going strong. Not everyone's experience though. When my ambient light sensor was on the fritz and the lights stayed on constantly, I had a set set last just over a year. The non Ultras should have a better lifespan since they burn cooler (less light)
that is true, but i was comparing to standard halogen bulbs. if the OP is on the fence, i would say try them. you are right when you say there are mixed experiences. some love them, some hate them.
Low bean bulb replacement requires proficiency in bean counting. :thumbs:
LoL, good catch! Well I replaced my magic beans with a set of sylvania silverstar's and installation was VERY easy. The only thing is I really don't see a huge difference between them and stock. Nothing like I did when I replaced my stock foglights with Silverstars.
The Silverstar bulb is pretty much equivalent to the stock bulb. The Silverstar Ultras are brighter
I've never had bad luck with Silver Star's last set i had lasted almost 8 years on my high/lows..only reason they were changed out was the light assembly's were changed out due to being sand blasted in a wind storm by a body shop who was doing the repaint. as for the DRL's on my 03 lasted the same amount of time with the Sylvania 3157 ALL
bulbs. maybe i'm just lucky, but i get longer life with them than the factory Wagner's..
BTW- putting a little dab of dielectric grease in the bulb plug helps also..
good luck..
You're probably right, I likely just bought into the marketing part of it I guess. "Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility." I thought they where referring to stock headlamps but really they never mention what the increase is compared to.
Nonetheless it's not that I'm unhappy with them, it's I just had expected seeing more of an improvement - similar to I did when I replaced my stock foglights with these Silverstars.
What does the dielectric grease do for the bulbs?
Blue coated headlight halogen bulbs actually provide less useable light output than your stock bulb. We recently started carrying the Putco Night White, Osram Nightbreaker Plus, and Philips X-treme Vision halogen bulbs. These bulbs do not have a coating on them and they will get you more light than your stock halogen bulb.
Steve
Steve
Haha, thanks Steve. If I can remember your companies name in a few years when my Silverstar's burn out I'll try to get a set of bulbs from ya. :lol:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
