What Water Temp Do You Normally Observe
today going home it didnt go over 160 haha.  It is like 15 degrees out though and my trip was 10 min.
My truck runs right under 210
Just a tad under 210 ...  my previous 98 Z28 consistently ran at a certain temp no matter 110 or 20 degrees out but when I refreshed the Dexcool it then ran consistently at a higher temp - I guess the new water/dex mix was different
Thanks for the replies!  I was a little concerned as I "thought I remembered" (which is dangerous) my 350 ran cooler. I looked down, when the outside temp was in the 40's, and noticed I was just a tad under 210.
Thanks again.
Our 98 Suburban ran at just under 180, thought that was odd and kind of cool but that is what the gage read.
:D
Answer: An inaccurate one.
Are we talking the analog dash gauge?
How many have verified their analog gauge's readout vs. the sensor's output via a scan tool?
FWIW, I EASE scanned it, and the difference was ~25*!  With the gauge showing high.  Probably why there are only widely spaced marks on the gauge.  BTW, I believe Porsche went to this style (something like  40* gaps between marks) on their oil temp gauge in the '80's when they could no longer keep their oil temps down after adding emissions/safety related weight, etc.  Probably just an accounting decision here.
Wish I knew where I posted the essay on this before...But:
Those of us from the pre-computer era KNOW that 180 degrees is target engine temp.  So to us,.. 200+ is runnin' hot.
But that's the old way vs the new way.
FACT:  The hotter you can run an engine, the more efficient it is.  So IDEALLY, the brink of boilover is the perfect operating temperature.  Which to us old timers is; "eeeeek I am about to overheat".
You can replace your stock 195 deg thermostat with a 180 or even 160 deg one if it makes you feel better - - But beeee careful....sometimes the computer may recognize this as being 'an engine that is not fully warmed up' and as a result, the computer could conceivably adjust the fuel/air mix and timing (alas choke the engine some) to compensate.  A performance robbing situation at best.
I would recommend leaving it alone if you are not overheating.   Conversely, a fellow who often tows a heavy load in hot weather.....I would probably go to a cooler thermostat in order to give myself some safety zone.
Which opens a question I have never thought about:
Q) In the absense of a separate transmission fluid cooler, has GM made any changes to their transmissions as a result of the increased operating temperatures?  I mean heck..if your radiator is holding 200 degree coolant instead of 180 degree...that has to transmit into higher transmission temperature right?
Heat = efficiency in an engine, but it =  :devil:  on a tranny!
