New member in south Georgia
manley
Hey folks,
I just traded my '07 Silverado 1500 for a '10 Silverado. I tow a pretty good sized camper (29' long, 6,500 pounds dry), and wanted to upgrade my ability...
The '07 was an extended cab Z71, 4X4, 5.3 with the 4-speed, 3.73 gears, LT2 option package, bucket seats & center console without leather, had 73,500 miles.
The '10 is an extended cab Z71, 4X4, 6.2L with the 6-speed, 9.5" rear, 3.42 gears (not the NHT), integrated brake control, LT1 option package, front 40/20/40 split bench with leather, with 9,500 miles.
I gained:
~3 model years
~Much better horsepower and torque numbers
~6-speed transmission
~9.5" rear end
~Integrated brake control
~Leather... and the bench is more comfortable than the buckets
I lost:
~Power passenger seat
~Self-dimming rearview mirror
~Rear window defogger (had never even been turned on!)
~Fog lights
~Best of all... 64,000 miles!
My trade deal was $10,000, out the door, including a Line-X over the rail liner. They gave me $18,100 for my truck, and I do believe I got an excellent deal...
I've always been a "bone-stock" kind of guy, but sure have enjoyed doing these few little add-ons:
~Leveling kit,
~Line-X upgraded to the X-tra (I wanted the UV protection and fade-resistance), ~Rugged Liner rear fender liners
~Du-Ha under the rear seat to stash my deer rifle and various "stuff." (I really like the Du-Ha, but dang, are they pricey or what?)
I am loving the new truck... even though the '07 was the new body style, there's just something I like about this one better!
Might be that sweet exhaust note! :)
scott
Big Congrats, You'll love the 6.2L. It's a beast.
Most of the things you lost, you can add for a pretty reasonable price. :thumbs:
Here's my "baby," finally got it just like I wanted it! 2" rough country leveling kit, line-x x-tra over the rail bedliner, Du-Ha under the rear seat (to hold the deer rifle and other assorted junk), added the "6.2L VORTEC" stickers to the hood, and Rugged Liners in the rear fender wells... also replaced the stock front (junk) speakers with some nice Kenwood 3-ways, because the previous owner had cranked it up one time too many.
Also, before I swapped the wheels and tires, I couldn't resist bypassing the stabilitrack and traction control... just once! That was, let's just say, "exciting!"
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
