pwr window works sometimes?
One of my windows (rear driver side) works intermittently. It always goes down but getting it back up is an issue. Sometimes it goes up fine, and other times I have to hit the switch a bunch of times to get it to work. It's not slow, it either works or it doesn't. Anyone have similar issues?
2009 pass rear window mostly when it cold outside. Summer works fine I havent spent much time trying to figure it out though as I dont roll the rear windows down much. Maybe someone will chime in with a solution.
I don't know what year your trucks are but on my 99 its the drivers window that will not work. Replaced motor still the same replaced switch still the same, checked with dealer and tech said it would need wire harness to vin to parts "out of stock no longer made" just my lucjk.:jester:
BMG09, mine is an 09 as well. It would make sense, temperatures just started dropping a bit here down in FL. I hope someone else can give more info or if you figure something out please let me know, it irks me when you dive a nice new truck and little crap like this doesn't work.
I have a 2010 and have the same problem with the back passenger window. We just noticed it. Seems to only happen when its cold, like stated above. It would be nice to know what is going on.
Sounds like the regulator is binding. I had trouble with my passenger side. Changed the motor/regulator assembly. Piece of cake. Works great now.
I took it in last week, it was covered under GMPP major guard. They replaced the switch, however, it started doing it again in like 6 hours, going to take it back in and suggest the motor/regulator be replaced as Tesnoboy stated above. Will let you guys know
  • 1 month later...
Finally an update, took it to a different dealership, they tested the switch (that the other dealer put in) and found it to be no bueno, put a new one in, took like 2 hours total, no problems now.
  • 6 months later...
RESURRECTION!
The same exact thing just started happening to my passenger side rear window switch, I have to take it in soon but am assuming its the switch again.
  • 1 year later...
I'm having the same issue with my 07 Sierra except both sides are acting up. It was the driver's side first; once it's down, it won't come up. I just noticed last week that the passenger side is getting intermittent now too. I have to pull the switch 2 or 3 times to get it to work. Doesn't seem right for a part that just isn't used that much. I've got kids that roll down the windows but 75% of the time it's just me in the truck and I'm not rolling 'em down with the rear switches while I'm driving!!
EDIT: Oh, and the reason I know that the switches aren't working is because now if the whole family is with my in the truck, my 15 yr. old son is doing the driving and the wife and I swap out who HAS to sit in the front!! (Nahhh, just kidding. He's doing a good job most of the time. We started him out early with a go kart then 4 wheelers and driving a jeep on our land and our friend's place...)
  • 4 weeks later...
2011 doing the same thing.. Thanks for the tip... I will check the switches. Wonder it its due to low use? Can you move the switches around or is it one cluster with 4 switches? I was thinking I could move one of the high usage switches for that one?
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
