Denali Sierra AWD Level kit options
Hello, seen some conflicting ideas on the topic of leveling kits for an 08 Sierra Denali with AWD. Does it matter which one I go with, seen RC was the choice by most. I want to lift the front maybe 1-2"s tops.
Id look on ebay for the fat bobs leveing kits its the same design and style as the RC but half the price i just bought one for my 08 silverado for 35 bucks shipped.
spend the least amount you can so when you have to take it off for vibrations you arent that pissed off.... OR lower the back to match the front, then do a small body lift. that way you'll be lifted and level.
thanks guys, anyone else have any thoughts? Is it ok to try or will I probably run into problem with it?
theres a good chance you'll run into problems wtih it since its AWD, when you change the angles on the front cvshafts it'll probably vibrate under acceleration. thats why i said if you're going to do it get the cheapest kit you can and do the labor yourself so if you have to take it off you're not out that much money... that or do it the other way i suggested by lowering the back to level it and then doing a body lift to bring the whole truck up level
  • 10 months later...
I've been looking around but can not find 2" rear shackles for a 2012 denali. Would any for silverado work? I am not going to deal with raising the front and will just lower the rear 2 inches to make it level. Any advice is appreciated.
I put a readylift kit on mine. It is an 09. I am running stock wheels and stock tires. I did not notice any vibration whatsoever. I also installed Air Ride airbags on the rear because I tow quite a bit.
