Power,Heated, Signal NNBS tow mirrors
Hey everyone, i have a set of Power, Heated, turn signal tow mirrors for NNBS Silverado's/GMC's. I received them as a christmas gift from my girlfriend but it turns out i don't like them on my truck as much as i thought i would, so I'm looking to trade them for a full center console for my truck in black. Let me know if anyone's interested in doing a little trading.
Thanks! :thumbs:
Are these the OEM ones? Got any pics? Interested in just selling them?
i can post some pics of them as soon as i get back to my house and I'm assuming they're aftermarket but i dont really know how to tell if they're OEM or not.
Would you be willing to sell them instead of trade? If so how much would you be wanting out of them?
If all else fails i would be willing to sell them outright but id really rather try to trade for either a full center console in black or a set of regular mirrors with signals and white caps.
lmk guys! :thumbs:
ok guys ill take some pictures now and post them when i get off work today. Again, i don't believe they're OEM but I'm not quite sure how to tell the difference because there aren't any markings and they came in just two plain brown boxes.
really sorry guys, I'm just getting a chance to reply now we've been absolutely swamped at work the last couple days. But at the moment i might have a deal in the works with someone local for the mirrors. But if it falls through ill let you know right away.
again, sorry for the delay
    • 3.19 @ Kroger’s in Montgomery Tx
    • We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
