Stabiltrack - Add to 08 Sierra?
forskare
I have a 2008 Sierra, 5.3, SLT 1500 All Terrain Z71 and would like to add Stabiltrack, if that's possible. If it can be added, Other than a software update and a Stabiltrack button, are there any mechanical parts that must be added, including wiring? Or am I lucky enough that the on/off switch is pre-wired.
Thanks much,
kenn
I know nothing about this system .... except that if it is possible, you'd better have deep, DEEP pockets. Just a guess.
Are you SURE you dont have it?
The Stabiltrak doesnt have it's own button, it is controlled by the same button for Traction Control. If you hold that button down for 5-7 seconds, it should turn the Stabilitrak OFF (and say so on the instrument cluster) Then at least you'd know if you have it.
I am pretty sure it was standard on Crew cabs but an option on ext cabs in 08. Hold the traction control button down and see if it goes off (5 sec for stabilitrac) If you dont have a button, you dont have it.
The sensors associated with it are expensive and won't be there. If this is even possible, it will cost a small fortune.
Body harness, steering column harness, steering wheel position sensor, yaw/lat sensor, ebcm and custom programming yes, you could have it.
Sounds pricey lol
LMAO !!!!
If I could give you my traction control and stabilitrac, trust me on this, I would, and for free, too!
Your truck should have it. Check your window sticker or have a dealer check it out for you....Try pressing and holding in your traction control button. If you have it, after maybe 5 seconds it will say "Stabilitrac disabled".
Should be a specific RPO code for this option as well in the glove box.
:lol::thumbs:
Just what you need with today's GM - another complex, failure-prone & expensive system to fix .... No thanks! :cheers:
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 495 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
