RC 2" level issues?
1800 for ball joints?
I know right. It was 850 for parts and 850 for labor. That price includes upper and lower control arms for both sides. I priced aftermarket parts and I can do it myself for around $250 + getting an alignment.
Holy crap. Where did you go? Grab one of those coupons for like 10% off repair from one of the dealers (maybe a chevy dealer???) around here.
  • Replies 36
Ryan,
The wife told me to trade it in and get a new truck. That's the best idea she's ever had!
BTW: Some friends of mine live in your neighborhood. Your truck looks good sittin in the driveway! :)
Thanks, If I could sell my Tahoe it wouldnt have to sit out :(
I went to the dealership yesterday to get some stuff done on the truck. While there they did their usual inspection and they noticed that my upper and lower ball joints on both sides were shot. I checked them myself and they are bad. I've had the RC 2" level on the truck for approx. 30,000 miles. I can't say 100% that it was caused by the level kit, but I bet it was. The cost for the dealer to fix is $1,800. I will be exploring alternative options.
Screw the stealership. IMO if I were you I'd pick up some nice uniball UCAs (Camburg, icon, TC, BMR) and install them yourself. Swapping out the UCAs is no harder than installing the leveling kit.
That was my plan until the wife told me to get a new truck. Who am I to argue with my lovely wife? So I picked up my new HD yesterday.
Looks like you lucked out :) I want a diesel!!!
The diesel would've definitely been cool, but $7,000 extra is a lot to spend for something I don't really need. (one could argue that I don't really NEED a new truck) ...damn, shoulda got a diesel. :lol:
i spoke with one of the companies that makes the uniball UCAs. sure they're nice but they told me that they usually get about 40,000 to 50,000 miles out of them. and even faster if you offroad. balljoints have the rubber seal around them to protect the critical joint from dirt and water which a uniball design is exposed to.
really depends on your specific application and what you use the truck for IMO.
The install is pretty easy. From prep to cleanup it took me about an hour. I found a video on Youtube with some shortcuts. They don't totally disconnect the ball joints or other bolts/nuts. I did it that way and it worked out just fine.
    liddlera
    liddlera
  • Who's Online   6 Members, 1 Anonymous, 393 Guests (See full list)
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
    • Pretty easy to just remove/drop the exhaust behind the manifolds. They're in no way hard to get to. Maybe 5min of work, and you get the opportunity to put some anti-sieze on them in case anything ever comes up, you eliminated the risk of snapping a stud.
    • I let the dealer do every other oil change simply so they can rotate the tires, which is a pita at home.
    • I addition, I won't have a pan full of fluid sloshing around to get all over the place.   I am putting on the Dorman pan with the drain plug. It looks like it is around the same height. I have one of these guys to make life a lot easier.   https://www.amazon.com/dp/B09CDXJCCT?ref=fed_asin_title&th=1
