ABS/hub issue again
About a year and a half ago, I had the all too common issue of the ABS kicking in when rolling to a stop. I removed and cleaned the wheel speed sensor mounting area but it didn't work. I replaced both front hubs and the problem went away. Now it's starting to to happen again. The hubs are from Napa and only have about 10K miles on them. I'm going to try the cleaning trick again but if that doesn't work, anyone know of a quality wheel hub that will actually last more than 10k miles? Factory prices are crazy but I'll go that route if they will actually last awhile. Thanks.
STAY AWAY FROM SKF Bearings. Junk. Find an ACDelco parts distributor. They can get you OEM Delco wheel bearings for like 200. It's worth it. They fit perfectly. The SKF ones I got really had to be mashed in. It isn't a good scene.
Anyone know who makes the Napa hubs? There were two grades available. I bought the cheaper ones, PBR930304. Wondering if they are under warranty still but I can't find any warranty info.
Timken, and be done with it!
Got mine from amazon.com for around $117!
+1. No issues from my timken wheel bearing replacement after 15 months and probably 20-25k miles. Replacement was absolutely identical to stock.
I will keep that in mind. I removed the sensors and cleaned the mating surfaces on both sides today. Hopefully that will fix it, at least for awhile. Interestingly, one side had a thin spacer under the sensor so these hubs must be remaned and the sensor head clearance on that one must not have been quite right? Either way, that one was rusted to hell after only one year, ugh. Stupid design.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
