Firmware Update
Was wondering...........
Is it necessary to update to the latest firmware on the OGM 1
If your not having issues with the OGM 1s performance??
Thanx
Tony
From many years of experience with firmware/software updates - if you are having no problems the update claims to fix and the update does not have enhanced features you feel you want, why update and risk problems?
However if you can go back to the earlier version easily if the new one causes problems, then the risk is essentially zero.
I would just hold off if you aren't having any issues. The only thing this one did, besides fixing some issues, is change the viewing of the camera.
Thanx guys.......
I currently have the Oct 28 2011 firmware......guess ill just wait till the next one
Tony
There will be a major one still sometime this month
-Josh
Sent from my Motorola Droid Razr using Tapatalk.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
