Messin with iGO
Tony1970
Ok...CPD......
auto_nightmode="0"
auto_nightmode="0"
which one?
You can change the default night mode in the Sys.txt file in the root directory to:
auto_nightmode=0. As to the info boxes my experience is that they are tied into the day/night sensor of the OGM-1 . The map is tied into the GPS signal and the time is calculated from that. I have seen where it can take up to 15 minutes for the map to change color when in auto mode yet the info boxes seem to follow the OGM. I have noticed the GPS side of iGO seems to be it's weakness, the altitude seldom works, the GPS screen seldom shows info and the tracking seems to be off by as much as 20 ft at times. I have even relocated my antenna in an effort to improve the signal with no avail. In reading some of the Forums this seems to be a common complaint.
is this exactly the way its supposed to appear?
auto_nightmode="0"
do i just add it on a new line to whatever is already there to the sys on the root of the card?
thanx
T
Ok...CPD......
auto_nightmode="0"
auto_nightmode="0"
which one?
auto_nightmode="0"
thanx
T
In the Sys file enter the following:
[device]
sdcard_name="SDMEM"
type="Audiovox_USA_OE"
[screen]
daymode_until_no_time_sync="1"
This will make the Map start up in daytime mode until the map sync's with the GPS (which may take up to 15 mins).
Once you have entered it Exactly as above go to file, save as, save it, and the exit.
I just can't seem to get this right. The system came fine with the settings that were preloaded. The only thing I wanted to change is add say street names in navi mode. I have done the syst configuration but it's still not working. Now it doesn't announce anything Is there any way to just add that one option or do I have to rewrite the whole syst text file. Am I making sense
