Where to get online?
im looking for front bumper for a 05 sliverdo. have not found any locally. wondering about online and who would have best price? i see LMC has it for $300 and $125 shipping.
Craigslist?
Rockauto.com
Shipping is going to be high because of the size
Ryan
well lmc has 2 different ones. the premium would be 300. the standard that body shops uses is 200. i buy a lot from lmc and find most of the time they have the best prices. but take a look at discountbodyparts.com http://www.discountbodyparts.com/catalog/?N=1588+9972+4294962952+9278&Nr=OR(brand:Replacement,brand:Kool%20Vue,brand:Perfect%20Fit,brand:US%20Auto%20Parts) all about the same price
I was thinking about that thought it would a lot going to call monday.
I don't think it's the size but the weight. Someone told me these steel front bumpers weigh 200 lbs. If that's true it might be worth your while to have a shop do the labor. Also I was told most likely some brackets will be crooked if the bumper was hit, and I think those are sold separately.
my dad took the old one off he sadid maybe 25+ pounds he did it by himself. I slid in to a tree with it last weekend icy and snow covered road. bumper, fog light marker light, brakcet that is broke. few hundred bucks in parts.
Must have been a typo in the advice I got. From the huge shipping cost I would've thought it was heavy.
200 lbs does sound too heavy, but I have computers that weigh 40+ lbs. How does a good steel bumper weigh 25 lbs.?
The bumper off my 2006 probably weighed about 25 pounds. No way even a steel one would weight 200. Mine has a stinking guard on it and only weighs 150.
My factory one is for sale, make me an offer if you're close to Salina, Kansas lol
its not the weight but just the size that makes shipping so much,
im in NY wonder how much shipping would be? how much are you asking for it? i have not had any luck finding one arund here. places want more for used one than new. not many out there.
what about Ebay? i see a few on there not sure how good chrome would be on it?
I looked at prices, and for something that big it looks like you'd be better off buying it close or buying it from a company that has access to cheaper shipping than I do. Looks like ~$200 to ship to NY.
Ebay is worth a shot.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
