plunk77 Posted April 4, 2012 Posted April 4, 2012 Will a 295/60/r20 terra grappler fit on a leveled truck with a +18mm offset wheel? also on a completely unrelated note is the search function not working for anyone else? If i put in any kind of numbers it always says no results found
Morgan1986 Posted April 4, 2012 Posted April 4, 2012 Will a 295/60/r20 terra grappler fit on a leveled truck with a +18mm offset wheel? also on a completely unrelated note is the search function not working for anyone else? If i put in any kind of numbers it always says no results found search function never seems to work for me too.
Big Whiskey Posted April 4, 2012 Posted April 4, 2012 No, that tire will not fit without some serious fender modifications. And yes....the search function now officially blows when it comes to searching for numbers.
txab Posted April 4, 2012 Posted April 4, 2012 295/60r20 terra grappler site:www.gm-trucks.com Best way to search the site is to use google advanced search and then specify gm-trucks.com for the domain. And yes searching numbers does not go well
plunk77 Posted April 4, 2012 Author Posted April 4, 2012 I knew 285/55/20 would fit so i ended up going with those. hopefully it turns out ok. thanks for the searching information it will help in the future
