Removed tailgate cap, busted clinch nut loose !
I'm detailing my 2008 All Terrain and decided to go a but further and freshen up the tailgate cap, only (4) screws - right ?
I get to #3 and it's a bit tight but I didn't sense it was frozen. I turn a bit harder then it suddenly breaks free then just spins, and spins and ..... spins.
Any ideas how I can fix this ?? I still need to remove the cap before I can begin to fix the clinch insert.
Help !!
take a 1/8" drill bit through the center of the screw followed by a 1/4" drill to get the head of the screw then drill it the "exact" size of the new nutsert you are going to insert in the hole , I think they are M8 metric in size for the threads
here is a video on the insert , watch at about 2:21 for how it works
You will want to watch that you do not get the bolt spinning when trying to drill. It will get hot enough to melt the plastic.
Hi;
when you watch this video you can see how the tailgate cap is fastened. They used nutserts as described in montyss post.
http://videos.etonne.../video/31503451
I'm thinking that the nutsert came lose.
What if you take out the door handle and try to reach inside with a pliers to hold the nutsert?
Just a thought.
so long
j-ten-ner
the factory nutserts have a hex on the backside you might get a wrench on it if its the one close to the tailgate handle , could be a 5/16 or 8mm I'll check it tomorrow for the correct size....
5/16 is 8mm. 3/8 is real tight on 10mm
    250.3k
    Head Scratcher
    Head Scratcher
  • Who's Online   4 Members, 0 Anonymous, 1,158 Guests (See full list)
